Question about Hotpoint Refrigerators
Hotpoint no-frost csh22gr won't make ice or dispense water
dididsaythat
  • 291 Answers
SOURCE: Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Posted on Aug 28, 2007
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
wheelshot
  • 102 Answers
SOURCE: water dispenser doesn't work on ge hotpoint freezer
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
Posted on Apr 11, 2009
SOURCE: Hotpoint CSX22GR water dispenser not working
The residule water in the line freezes, you need to unthaw the freezer door. Then you constantly need to use the water from the dispenser to keep it from refreezing.
Posted on Apr 12, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
Frozen water dispenser
Take a small hand cloth or a 6-inch by 6-inch cloth and wrap it around the water line where it freezes up. This will help insulate the line. Failing this, do you see frost or ice forming anywhere specifically around the door - if so, the door seal would need to be replaced at a cost dramatically less than US$400.
Nov 01, 2017 | Hotpoint 21.7 cu. ft. Side-by-Side...
Ice maker won't make ice
This problem is very common.The ice maker water passing line gets clogged or blocked by ice cube or gets frosted by ice or the water valve,which lets water to ice maker,tray, that valve gets faulty.
The ice maker not working.-------------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Hotpoint ice dispenser door not sealing
clean with white vinegar to remove lime deposit.
flapper may have got bent, bend back or replace flapper.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Jun 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
26 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
