Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Intermittent Dishwasher fault Zanussi 23 in. ZDT6252 diswasher only partially drains in some of the wash cycles. I suspect it's a faulty float valve & sometimes too much water is taken in at the start of the cycle. Anyone else come accross this??
Fixed the problem by replacing the ELECTRIC ANTI-OVERFLOW VALVE. Simple enough installation - bit fiddly.
Posted on Jan 12, 2009
Drainage working always
Check drain valve. Clean the valve seating area.
May 25, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwasher power there but wont fill up with water makes a slight buzz sound any ideas please ?? It's a Zanussi zdt6252 by the way..
The slight buzz is coming from the water inlet valve solinoid. It's OK.
But check whether water is getting into the inlet tube of the washer. Check the filter at the rear of the dish washer body wher the inlet tube from your water tap is connected.
Apr 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwasher wont fill with water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Sep 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
My the dishwasher will not drain. The pipes are not blocked or kinked. If I shake the pipe the dishwasher will drain. But I cant do that all the time. Any suggestions?
Hi..
If your dishwasher will not draining you need to check this
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Good luck !!!
Regards
PCmania
Jul 13, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Water not draining completely
I fixed a similar problem by changing the ELECTRIC ANTI-OVERFLOW VALVE located at the back of the machine.
Dec 01, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 fills with water when not in use
Sounds like you have a leaking inlet valve. The best option is to replace it with a new one. It does have overfill protection on it but this may not work if its leaking.
Nov 13, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt6053 will not fill with water, on any programme, it appears to try to start and makes a moise as if pumping, but there is not water to drain, and pump appears to operate if water is poured into...
Check float valve. It is probably stuck. This tells yuor machine to pump the water out and keeps the water valve from opening. Often it is something small that was placed in the dishwasher and lodges under the float telling machine that it is full of water when it is not. The float is somewhere on the bottom inside the machine typically. Make sure it moves freely.
Jan 15, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
336 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
