Belkin N750 DB (USB ADAPTER) hardware causes Blue Screen Of Death
This is my computer responding to the hardware/driver. I have all the updates possible. Windows 7. I've checked the Stop Code on Microsoft. I've downloaded the Hotfix from Microsoft. Still I just can't seem to get my computer to run properly with it.
  • 7,733 Answers
sandrew
  • 2961 Answers
SOURCE: Zyxel Zyair B-220 802.11B Wireless Adapter
This will be happening because of a driver conflict. Uninstall all drivers to do with adapter, then re- install your Zyair software and then plug in your adapter, but force windows to look where you have downloaded the driver in other words not automatically install but manually when the option pops up. It may be you have to connect your adapter first then install drivers.
Posted on Dec 14, 2006
SOURCE: D-Link DWL-G122 Wireless USB Adapter
I think before this works, your going to need Windows XP Service Pack 2 i'm sorry to say... If not just scrap the whole thing and run on Vista and get hounded by a million start-up pop-ups
Posted on Jan 23, 2008
SOURCE: Belkin FSD7050v4 driver for Windows 7
just installed my belkin wireless g usb adapter on windows 7 64 bit down loade driver from belkin right click run in compaterbilty mode windows vista service pack 2 and install
Posted on Nov 19, 2009
Testimonial: "It's been a while but i did get it working and I believe this is what i ended up doing. thanks."
Tom Marvolo
  • 708 Answers
SOURCE: Windows 7 driver update for Belkin F5D9050
Im Not sure this will Work
But in most Cases it will So I think its Worth a try
You will need to find the version of the Adapter
And After that Goto www.belkin.com/support
On the top right hand side on the search type F5D9050
On the results select the Link that has the Drivers
Download the Driver for the version of your Adapter
Right click on the downloaded file and select Properties
Click on the compatibility tab
Select Run this Program in compatibility mode for Windows Vista SP1
Click Apply
Now install the Drivers
Posted on Jan 12, 2010
Testimonial: "It´s working fine now, thanks!"
  • 10406 Answers
SOURCE: Sometimes my WUA USB adapter desactivates itself.
Try the adapter on some other computer.
If it still has a problem, then it needs to be replaced.
Posted on May 14, 2010
Usb ports do not light up
You are not the only person having problems with the Belkin N750 DB Wireless Dual Band Router. Are you using the correct cables? One more thing you can check, does it have a reset button on the bottom or the side? Try those two things.
Feb 12, 2014 | Belkin N750 DB Wireless Dual Band N Router
Blue screen compaq presario windows xp sp2 cq40
Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:
Startup using Last Known Good Configuration to undo recent registry and driver changes.
Use System Restore to undo recent system changes.
Roll Back device driver to version prior to your driver update.
Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If this doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Oct 10, 2013 | Compaq Presario Notebook
Blue screen
If this didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Sep 30, 2013 | Microsoft Windows Vista Ultimate Edition
Over heats blue screen
Follow these suggestions to solve your problem
- Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
- Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
- Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Sep 17, 2013 | Facebook Social Network
Blue screen death
Sep 07, 2013 | Advent Computers & Internet
Stop:0x00000024
The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did.
1) Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:Startup using Last Known Good Configuration to undo recent registry and driver changes.Use System Restore to undo recent system changes.Roll Back device driver to version prior to your driver update.
2) Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
3) Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
4) Return hardware settings to default in Device Manager. Unless you have a specific reason to do so, the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
5) Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
6) Use a system utility tool like Reginout for an instant fix.
Apr 27, 2012 | Dell Computers & Internet
Belkin n750 db connects with windows 7 laptop, but will not connect with xp laptop. It will not let me enter the password.
It is possible that, if you have the router set to wireless N only, your XP machine won't interact with it. Your XP adapter probably doesn't support wireless "N"--you'll have to tell the router to use "N" or "G"
Apr 21, 2012 | Belkin N750 DB Wireless Dual Band N Router
My computer says stop: 0x00000024 (0x00190203,0x86f6e330,0xc0000102,0x00000000) `
The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did.:
6) Use Reginout to fix BSOD stop errors
Apr 17, 2012 | Dell Inspiron 6400 Notebook
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
