Dimplex rdh1507tcw not coming on after installing
It is wired on 240 am following electrical diagram
5 Suggested Answers
  • 232 Answers
SOURCE: I need a wiring diagram
you can get from www.dimplex.com
Posted on Sep 15, 2009
SOURCE: How to install a wall dimplex thermostat to a
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Posted on Sep 21, 2010
SOURCE: dimplex rdh2010TCW 240 volt fan heater?
From the manual: Care should be taken to provide a minimum
of 8" clearance from floors, ceilings and adjacent walls
SOURCE: wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Posted on Dec 11, 2010
I am replacing an old booster pump with a Polaris PB4-60. I have three wires, One Red, One Blue, and One Green. Now I know the Green is Ground, but which poles do the Red and Blue go? Both seem to say...
It is impossible for us to know what voltage you are running as you did not list that information here.
Typically a green-red-blue comination of wiring suggests 240 VAC connections.
Also, every motor you buy is required to have a wiring diagram on the side of the motor. This should tell you where to connect the wires.
IF you are running 240 v as suspected, both the red and blue wires are "hot" wires on the load side of your timing box. Simply look at the side of the motor and follow the diagram on wiring the pump.
Typically most motors in the USA use a L1 and L2 terminal to connect the 2 "hot " wires.
This pump does come factory wired for 240 volts, so it probably is just 1 each of the "hot" lines to L1 and L2.
Before connecting, make sure you confirm your systems voltage with a multimeter.
Below is a link to the installation manual for this pump. But it does not list electrical diagram since its on the side of the motor.
http://www.clubp.info/pdf/TL/P-134.pdf
Mar 22, 2011 | Polaris Pb4 - 60 Booster Pump
The wires inside the unit are marked L1 and L2 along with a green ground wire. What do the L1 and L2 wires connect to ?
L1 and L2 are the "line" wires where you connect the power TO the heater....
Check the voltage on the name plate. but it probably wants 220-240 volts...
heatman101
Sep 16, 2010 | Dimplex CUH05B31T Electric Compact Heater
Wiring diagram for Dimplex wall heater Model 6100770000
Jul 16, 2010 | Heating & Cooling
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
Mar 03, 2010 | Heating & Cooling
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
