Question about Skil Saws
Having a problem getting the right saw blade for my Mcallister fold Dow saw
2 Suggested Answers
  • 236 Answers
SOURCE: I am not having much luck with blade alignment on
Check that the washers on the motor shaft are positioned properly. I believe the washers are dish shaped one should be on each side of the blade with the wide shoulder aginst the blade. Check this. Also if you go to Deltaportercable.com you can get an owners manuel for free on line. If this was helpful, please leave feedback.
Thanks, Snugglepants
Posted on Nov 03, 2009
The guide assembly on my 14" band saw will not stay peralell with the blade as it goes from the top of its travel to the bottom. it goes right to left going up and reverse going down the blade . the o
Sounds like something's bent. You might need some replacement parts. 14" band saws, regardless of brand, are generally made with Chinese parts that are knockoff Delta-Rockwell parts from many years ago. Grizzly sells most of these parts at reasonable prices. Check the exploded views of their saws to see if the parts match. Craftsman parts are expensive, even though they're the same part.
Mar 30, 2014 | Carter Products Rikon 14" Sears 14"...
I have a 10" band saw model 124.214000 how much tension do i need put on blade or the proper way to adjust the tension.
I've been having hard times also putting right tension on my Haltbar blade . Try reading this blog : http://bandsawblog.com/blade-tension/
Hope that helps.
Feb 08, 2013 | Cars & Trucks
How dow i change the blade
I am not sure if you can apply these steps with your band saw but you may use this blog for reference : http://bandsawblog.com/replacing-the-band-saw-blade-on-your-band-saw/
Where did you get your new blade? I got mine on www.sawblade.com . Works pretty well. Anyways, goodluck then. I wish I can give you more help .
Jan 31, 2013 | Craftsman 12 Tilt Head Band Saw Owner...
How do you fold a bandsaw blade?
gently twist it in half and then fold back against itself. USE gloves when doing this. Once you make the ftwist it will sometimes naturally fold.
May 23, 2011 | Delta 28-052 14'' Band Saw Blade for use...
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
How to install new blade in Buck bros keyhole saw. It comes with two blades, with the wood blade installed. How do yo remove thw wood blade and install the metal blade?
There is a slot at the back of the blade. Bent the blade out enough to clear the notch in the handle and fold the blade down.
Feb 09, 2010 | Hand Tools
14'' Sears craftsman bandsaw blade slips off, not much power
It sounds to me like the blade has stretched which the do in changing temperatures.
Try replacing the blade before you give up altogether. i was having the same problem with a Ryobi Blade would come off whenever i tried to cut a pice of 3 ply. I eventually replaced the blade and all ny troubles evaporated.
Aug 29, 2009 | Saws
Saws Logo
59 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tim Venetis
Are you a Skil Saw Expert? Answer questions, earn points and help others
