SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
SOURCE: INDESIT Washing Machine
Probably the pump or hose is blocked, remove the cover along the front bottom, of the machine, remove the filter and clean out, ensure the pump impeller is clear of debris and rotates freely.
refit the filter and try again.
SOURCE: indesit washing machine flooding when filling
if you washed coins, it is quite possible you have breached outer tub with them.
SOURCE: the washing machine doesn't recognize its
u select any program then turn off by the wall then you turn on and select another and turnoff by the wall wait 10 mins then turn on select the program you want and will work, theres another link on the internet somewhere ive seen it.
