Maytag Washer not working...
Shortly after cycle started, the washer stopped - no functions are working, appears there is no power.
* checked outlets - functional
* moved internal components to determine if load was unbalanced
* unplugged and plugged in device - still not working.
* checked water supply - functional
* checked drain spout - functional
* no apparent leaks (gentely moved washer)
  • 1 more comment
  • gonedownsout Jan 11, 2009
    thank you...washer is about 15 years old, is it worth fixing?
  • Anonymous Jan 13, 2009
    There is a new twist to this thread. I removed all of the clothes from the washer in preparation to drain the tub. As I did, the water turned on to fill to meet large capacity requirements.
    I let it fill, nothing happened. I moved the dial, moved the internal components, pushed all the buttons - nothing.
    A bit frustrated (cause now there is more water to drain) I slammed the lid - the cycle started back up.
    Here's the twist...the works except during each phase, I have to open and slam the lid down (pressing down on a closed lid does not work).
    Now what?
    thanks to everyone who posts here, this was my first time and I received very quick responses. I am very grateful for your help.
  • thomas
    thomas Oct 21, 2013
    most likely it is the lid switch.
    Problem Solver:
  • 14 Answers
Bushes on electric motor worn need new ones this will cut supply to washer
Posted on Jan 11, 2009
  • aimmclatchie Jan 12, 2009
    should be if motor is not damaged
Whirlpool washing machine style master #907675 just stop working in the middle of the wash cycle and won't start again.
Susan, First make sure there is still power to the outlet washer is pluged into, may have tripped the breaker/fuse. Could be something as simple as a loose wire/plug, lid switch to something worse like control board. Have a good Tech. diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Troubleshoot washer stops mid cycle won drain or spin
Whirlpool Kenmore Maytag Washer Repair Fills Then Stops mid cycle
Fix Your Home Appliances Instantly
Washer just stopped working all together in the middle of wash cycle
Jul 03, 2016 | Whirlpool Washing Machines
How do i reset my kenmore he 2 washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2010 | Kenmore HE2 Plus Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
187 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
