Question about Lexmark X422 All-In-One Laser Printer
"Service Connection Failed"
I am trying to scan documents and email them to a colleague. I proceed as normal, but the printer can not connect to the server! What is the solution please? Evelyn :D
  • Lexmark Master
  • 705 Answers
Check the most obvious things first: Is the network cable attached and are the lights on/flashing Does teh machine have the IP info configured properly or has someone fiddled and messed it up? Is the phone line connected and operational? So many times the cable has got yanked out without being noticed.
Posted on Jun 11, 2007
Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
I used to be able to scan a lot of documents and then just last week I couldn't scan any document using the Ricoh Aficio Type 2018. The message "Sending has failed. Press Job Information key to check the...
It is a problem with the network connection, if you are using scan router recheck the configuration settings in case of scan to email check connection with smtp server, port no. ssl on or off and do the connection test, check mail server authentication, rest assured it is not a problem with the machine or GW controller.
Feb 18, 2015 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh scan email
get operation manual for email and scan will explain how to set it up. or have copier technician come out.
May 14, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Server connection error when scanning
have you set up your scan Email account with you page Scope disk with the copier. is the server set up for scan to email. Also check the konicaminolta web site for scan operator manual. Down load the scan programs
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 24, 2010 | Konica Minolta Bizhub c203 Copier
HOW TO EMAIL SCANNED DOCUMENTS FROM HP J4580 DIRECTLY?
It is not possible to email the scanned file directly through the printer. However, you may send fax over the Internet
You may subscribe to a low cost phone service that allows you to send and receive faxes with your device by using the Internet. This method is called Fax over Internet Protocol (FoIP). You probably use a FoIP service (provided by your telephone company) if you:
• Dial a special access code along with the fax number, or
• Have an IP converter box that connects to the Internet and provides analog phone ports for the fax connection.
NOTE: You can only send and receive faxes by connecting a phone cord to the port labeled "1-LINE" on the device. This means that your connection to the Internet must be done either through a converter box (which supplies regular analog phone jacks for fax connections) or your telephone company.
Some Internet faxing services do not work properly when the device is sending and receiving faxes at high speed (33600bps). If you experience problems sending and receiving faxes while using an Internet fax service, use a slower fax speed. You can do this by changing the Fax Speed setting from High (the default) to Medium. For information on changing this setting, see Set the fax speed. If you have questions about internet faxing, contact your internet faxing services
support department.
(Ref from the manual of the printer.)
Hope this helps.
Jan 23, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I scan a document into a pdf and send by email
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr21
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Error 350
Error 350 means...
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Try this solution...
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved. (To turn off the ECM, simply press the setup button on the pritner, use the right arrow and select advance fax setup on the options. Press ok under advance fax setup. Use the right arrow and select Error Correction Mode. Press ok and select Off.)
*Try sending at a lower transmission speed. (To lower the transmission speed. Press the setup button, go to advance fax setup. under advance fax setup, look for Fax speed. change the fax speed to slow)
After you have done the T/S, try sending a fax again.
Hope this would resolved your issue.
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Lexmark X422 All-In-One Laser Printer Logo
293 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
