Question about Chamberlain Clicker Universal Remote Control KLIK1U
I have a 2005 genie pro screw drive opener, the remote quit working & I bought a new one . It wont work
2 Suggested Answers
  • 1082 Answers
SOURCE: I have a 1990 Wayne Dalton opener with remote
The system is limited in the number of openers it can store. Usually 3 though I don't know about your model..
You need to clear all stored openers, and then re-add what you want to use. If there are 4 or more it will not work.. The last one entered will be replaced by the new one. (What you're getting now)
Usually to clear memory, hold down the program button for ten seconds or so.
Wait a few seconds, start installing your openers.
Good luck
Posted on Dec 27, 2010
Learn button on genie pro max garage opener is not working . How can I programm new remote?
if the learn button is truly bad you have two options either replace the circuit board or buy an external receiver. It was me a would replace the opener with a Chamberlain/Craftsman or Liftmaster belt drive opener. The new genies aren't worth a damn. I've replaced about a dozen that were a year or less old because of defects this year.
Nov 07, 2016 | Genie Pro Building Materials
Can I use tje existing screw/rail of the 1/2HP Genie CM86001C and replace the old head with the new PowerMax 1500 head or does the new PowerMax 1500 require a new screw/rail?
No rail wont fit quite right. I would consider a liftmaster/craftsman/chaimberlain with yellow antenna wire. The liftmaster models are 8355 or 8550. Not sure how those model #'s translate to the craftsmans and chaimberlains. These units use 3 frequencies which are chosen automatically by opener radio. This gives you the best option to avoid interference. Genie typalically uses 2, but their fixed, so its a crapshoot to avoid interference. Do not confuse these frequencies with the rolling code feature which is a static frequency with only the "channels" changing.
Mar 28, 2015 | Genie Garage Door. PowerMax 1500 1 HPc DC...
Can I use a chamberlain remote with a genie pro garage opener
you can try to see if it works but probably no- get anather genie remote
Oct 02, 2014 | Chamberlain 953cd multi-function 3-button...
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Feb 07, 2012 | Home Security
Genie Screwdriver, garage remotes won't work, batteries are fine.
Your receiver has quit working. A call to your local Genie dealer should get you back in business.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Only one opener works the other stopped working
Are you sure you bought the correct remote? All are not the same.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie excelerator/
Check to see if the Vacation switch is locked on your wall console. It is a switch on the top of the black wall button. If that is not the problem it sounds like you need to program your remotes. Drop down the plastic cover towards the back of the unit There is a learn button push that and a red LED will come start flashing press and hold the button on your remote until the LED stops flashing (solid red) press the button on your remote again and the light will go off. This will program a remote
Here is a copy of your manual
www.geniecompany.com/docs/GENIE%20EXCELERATOR-ENG.pdf
Oct 12, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Clicker Universal Remote Control KLIK1U Logo
255 people viewed this question
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
