Lcd tv wont turn on, checked power and capacitors
  • 1,238 Answers
You possibly have power supply board problem
Posted on Dec 03, 2012
  • 16 Answers
SOURCE: lcd tv
dos the porew light stay red or turn blue or not at all?
Posted on Aug 24, 2008
aymantn
  • 109 Answers
SOURCE: lg 32 lcd tv will not turn on checked fuse in plug
eBook about LCD repair
Posted on Mar 17, 2010
SOURCE: Sony Bravia KDL-40S20L1 lcd tv has no power no lights nothing
My Sony Bravia LCD Model-KVL37S400A is not getting the Main Power supply. The LCD is not getting switched on. When i am trying to switch on the set nothing is happening.
Posted on Dec 24, 2010
  • 8909 Answers
SOURCE: 40" tevion lcd tv. modek no lcd 4040.wont come out
It should be fixeable. Does it do anything now?
I would blanket change them all.
Posted on Feb 18, 2011
casperaugust
  • 85 Answers
SOURCE: LG LCD 26LX1D power blinking red ,all capacitor on power board are ok
try replacing relay on power supply had this twice on lg and goodman lcd tvs
Posted on Nov 25, 2012
TV KEEPS TURNING OFF AND WONT STAY ON
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 13, 2015 | Televison & Video
My tv wont turn on. it is plugged in and the outlet is working
- Flickering screen
- Dim screen
- Slow start
Mar 02, 2015 | Televison & Video
TV WONT TURN ON/ONLY RED LIGHT BY POWER BUTTON
- Flickering screen
- Dim screen
- Slow start
Feb 19, 2015 | Televison & Video
TV wont turn on after dusting
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | Scott LCT37SHA TV
Turned my TV off and now it wont come back on
Possible bad capacitors on the power supply board which is a very common issue with most LCD televisions. Just check the tops of the capacitors on the power supply board if they are puffed up on top they are bad. They should be completely flat on top.
Feb 01, 2013 | Sylvania LC195SL9 19 in. LCD TV
My toshiba tv 32rv530u wont turn on
Replace the damaged capacitor and check first. If it do not help you, replace the power supply regulator board as card. It will be best, rather than trying to make the present one get repaired.
Jan 09, 2013 | Toshiba 32" regza 32rv530u 1080p...
When i turn off tv it wont go back on for hours
The most likely issue is your power supply is failing. Most likely issue that would cause this problem is bad capacitors on the power supply.
What happens in the above situation is:
After the Tv has been off for some time the electronics and capacitors are cool and supply the correct voltage so the TV turns on.
After using the TV the electronics heat up and the material in the capacitors expands causing the power supply to supply incorrect voltage. With the TV the power is flowing and is close enough to the correct values for the TV to stay on, after being shut off the TV will not turn back on because correct voltage is not present until the components cool down and the voltage at power on no longer engages the protection circuit.
Info on checking and testing power supply's
Info on finding and repairing bad. Damaged, leaking or swollen capacitors
Jun 07, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
Samsung lcd wont turn on just keeps clicking
Check for swollen capacitors on the power supply board.Very common problem on samsung lcd tv's.
Aug 28, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Mar 20, 2009 | Televison & Video
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
