Question about Sharp MX-2300N Color Copier
How do I run a sky shot on my Sharp MX2300N photocopier
Call for service Code:F2-40
  • 990 Answers
SOURCE: how to reset u2-40 for sharp AR266 photocopier
Hello sir; I'm not recognize this model number please double check,but I give you closer one to reset;
1, press "program", "interupt", "clear", "interupt".
2, enter 16 press start.
3, turn machine off and back on .
Posted on Jun 02, 2009
  • 120 Answers
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Posted on Jul 09, 2009
  • 22 Answers
SOURCE: error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
Posted on Aug 13, 2009
  • 33 Answers
SOURCE: Scan to email will not work
The pop server information would be different now this can be set by typing the printers IP address into an internet browser it should bring up a web page for the printer ISP can provide you with pop server
Posted on Jul 20, 2010
xptareq2000
  • 1447 Answers
SOURCE: pls i need the code
U2 04 mean eefrom read write error serial communication error
Posted on Mar 25, 2011
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
How do i fix a problem when AR5518 SHARP COPIER DOES NOT VERY WELL AND SHOWS F2,40
It sounds like a defective toner cartridge. You can try removing it and shaking it well and then Reinstalling it. Power the machine off and back on and see if it works. If that doesn't work you can try another toner cartridge. Also if the cartridge is empty and you keep installing it, it will disable the cartridge and the code will come up immediately when that cartridge is inserted.
Mar 31, 2015 | Sharp Office Equipment & Supplies
F2-40 repeatedly on a new Sharp MX4110 machine
during setup the machine do,nt install toner during calibration 25-2 steps: 1. Execute Simulation 25-01 and verify that the TCD_K value is less than 26. 2. Execute Simulation 7-1 and highlight [DV Check Disable]. 3. Open the Doc Feeder. 4. Place a piece of white paper in the lead edge area of the platen glass covering about 1-2 inches of the lead edge area of the copy. This will prevent jamming in the Fuser Unit. 5. Run 50 sky shots. 6. Check Simulation 25-01 and note the TCD_K value when it stabilizes. 7. Repeat steps 2 through 6 until the stabilized TCD_K value of Simulation 25-01 is 40 or higher. 8. Execute Simulation 7-1 and verify that [DV Check Disable] is not highlighted. 9. Hit CA and make sure machine comes to a ready state. 10. Turn Machine off/on. Make sure it comes to a ready state. 11. Make a copy and check the copy quality. 12. Run Copy Quality adjustment 12a according to the service manual if necessary. Note: TCD_K value of 26 or less will cause the MFP to display F2-40 error code. Remember that the TCD_K Value is inversely proportional to the Toner Concentration. If the TCD_K Value is stabilized at 40 or higher, then the F2-40 error code will not appear. Once you recover from the F2-40 Error Code, the MFP's Process Control will take over and regulate the Toner Concentration.
Sep 13, 2012 | Sharp "MX-4100N Copier, Printer, Scanner...
Sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Nov 14, 2011 | Office Equipment & Supplies
Since I've installed snow leopard on my mac, I can't use my new printer Sharp MX2300N any more 'cause it's not supported by SL: any solutions? Thankyou
Go to http://support.sharp.net.au/drivers/driversearch.asp and select photocopiers and select your printer model and you should be able to find the 10.6 drivers
Oct 05, 2009 | Computers & Internet
Error code H5-01 sharp MX2300N
pascale_algu
Good Luck
Aug 13, 2009 | Sharp MX-2300N Color Copier
I have problem sharp mx2300n everytime sign replace usedcontainer sharp mx2300n
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 24, 2009 | Sharp AR-C160 Color Copier
Error Code: E7-21
plaese hepply this problem
Aug 10, 2008 | Office Equipment & Supplies
Sharp MX-2300N Color Copier Logo
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
