Question about Siemens Refrigerators
Siemens refrigerator KG44U123 : Loud noise while operating. Possible ice build up. Please advise what to do. Thanks
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
  • 531 Answers
SOURCE: ice container loud noise
icemaker
Posted on Apr 02, 2009
  • 531 Answers
SOURCE: Roper refrigerator stated to make loud anoying noise
check and hear were noise comming from
Posted on Apr 07, 2009
shastalaker7
  • 1515 Answers
SOURCE: ice on refrigerator motor?
The fan in question is the evaporator fan motor and is hitting the ice. The problem is the freezer is not going into defrost due to a faulty defrost thermostat , heater, or timer. You have to call them back out free of charge on there 2nd time out and have them repair it right.
Sincerely,
Shastalaker7
Posted on Dec 30, 2009
Testimonial: "Thank you!"
I just got the side by side Frigidaire professional and every few hours there is a loud noise that comes out of it that last like 3 seconds
Thanks for your post, friend!
I see that your Frigidaire side by side refrigerator is making a loud noise every few hours. There are a lot of normal operating noises within a refrigerator. It is possible that your evaporator may create a boiling or gurgling noise. Or you could be hearing ice being released into your ice bin. If you have your manual they should list some normal operating noises within your refrigerator. I hope this information has been helpful. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Whirlpool refrigerator model ed5phexnloo loud noise & ice build up.
If this unit has a ice maker, when it fills the tray, water spills out around the fill tube. The water drips down and builds up around the fan over time. Need a drain line extension to slide over water line, should take care of issue.
Aug 18, 2012 | Whirlpool Refrigerators
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Thanks
samedayappliancerepair.ca
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
I have a GE side by side refrigerator with ice maker. Refrigerator has been fine and now it just started making a loud like humming noise which is coming from the freezer the ice maker works when I open...
Sorry to read about your problem, I hope this helps you out.
it maybe your fan, going bad. or you have a ice build up, and its hitting the fan..if this is the case, you have a defrost issue. or a bad fan.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Avanti Beverage Cooler BCA5105SG running very loud.
Inside the cooler is the evaporator fan usually right in the middle behind a cover. As it slows down you have less circulation and ice forms quicker and cooling is diminished. Sounds like it is going out.
Sep 14, 2009 | Avanti (BCA5105SG) Beverage Cooler
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Refrigerators Logo
Top Siemens Refrigerators Experts
marlin siecinski
Mai Lor
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
