Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi x26 RY28000 model won't start
Had a hole in primer bulb. Replaced part and now won't start. What could be problem??
jyackle5
  • 8197 Answers
SOURCE: RYOBI TRIMMER
here you go. this is the site that you need.
http://www.psep.biz/store/walbro_primer_bulbs.htm
Posted on Dec 16, 2008
  • 248 Answers
SOURCE: ryobi ss30 weedeater not starting after repair,to the primer bulb
Follow the instructions exactly. If it won't start, take out the spark plug to see if it is wet, or dry. If it is too wet, the motor may be flooded. If it is completely dry, you have to figure out why it's not getting gas. I am assuming you are pressing the bulb the recommended number of times, and that there is gasoline in the bulb, providing some resistance to your pushes with your thumb.
Posted on Jul 25, 2009
TeleFurb
  • 16 Answers
SOURCE: ryobi weed eater ONLY RUNS WITH CHOKE ON HALF WAY
Check the carb jets, they might be a gummed up!
Posted on Aug 25, 2009
rwvanlue
  • 486 Answers
SOURCE: primer bulb will not fill
There are aprox 5 sizes of primer bulbs that are common to trimmers, blowers, saws. You will need to be specific about carburetor brand and type when looking for a bulb. A small engine repair shop should have access to any of them.
Posted on Nov 25, 2009
Won't prime the carburator to start
If the primer buld is hard to push or wont return to shape like its supposed to then there is an obstruction in the carb. If it just wont move fuel then there is a hole in the fuel line or the fuel line is rotted off in the tank.
If the primer bulb itself is discolored ( should be clear not brown) it should also be replaced.
Nov 08, 2012 | Homelite Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Is the primer bulb necessary?
I dont think you should do that since the primer bulb is what gives gas to the carb, on most models.
Jul 28, 2012 | Ryobi Garden
I have Ryobi Weed Hornet Model RWH1100A MKIII and the primer bulb has disintegrated. I'm told spare parts are not available as this model is not made any more. Is there any way I can bypass the pr
The primer only pulls fuel from the carb, into the bulb and dumps back to tank, this is a starting aid so there is always fresh fuel in the carb, you can just blank of the pipe from the carb to the primer, this will just turn it into a standaed non primer carb, if it starts ok just useing the hoke then leave that way
Mar 14, 2012 | Garden
Hello, my Ryobi 410r tiller/cultivator needed new fuel line so I bought the fuel line, return and a new bulb primer. Unfortunately, I can't remember what hose goes where!!! Specifically, I've...
The primer pulls fuel through the carbruetor
So take your return line from the carb. and hook it to the inlet side of the primer and the other side
of the primer bulb transtions into the fuel tank.
You know when you have hooked it up right when you press the primer it fills with fuel and dumps back into the tank.
Jun 16, 2011 | Ryobi Garden
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Ryobi cultivator won't start. Just had the gas lines replaced
it could be a pin hole leak in the primer bulb.
Jun 21, 2010 | Ryobi Cultivator
Ryobi gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. if that doesn't work have the carb repaired at a service center or replaced.
Jul 05, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
146 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
