Question about Matrix Music
I need a manual for a silvertone guitar tuner stun1 need to change the battery
5 Suggested Answers
PolyrhythmFX
  • 109 Answers
SOURCE: I need guitar schematics for a silvertone by Samic
Go here: http://www.seymourduncan.com/support/wiring-diagrams/
Select you pickup/controls/switch configuration and it will show the corresponding wiring diagram.
Posted on Jun 20, 2009
  • 5603 Answers
SOURCE: Have no idea how to use it
I can't find info other than the tuner has three lights for flat on, and sharp.
given that you would plug it in and do a close tune of the guitar by ear.
Then you would strum one string at a time and tweek the peg tighter if it shows flat, looser if it shows sharp, until it shows the light right on.
I would recommend you get a book on guitars to learn how to tune and also check the setup of the guitar.
Also I would recommend you get a Korg tuner... they are about $20 from online sources and they are much easier to use.
Posted on Feb 20, 2010
  • 1137 Answers
SOURCE: i want to see how much my guitar is worth
Try this l;ink:http://www.jedistar.com/jedistar_vintage_guitar_dating_h2.htm
Posted on Apr 03, 2010
electrotech1
  • 1126 Answers
SOURCE: Ive used my guitar tuner
It probably has corrosion going to the battery pack, take it apart and get it resolder, at the batt
Posted on Mar 02, 2011
Don't know how to turn on tuner
put a battery in your guitar. It goes in the space at the bottom, usually where you connect your cable to your amp.
Then hold the guitar as you usually would.
Look for a little board with buttons on the side of the guitar to turn on the tuner: )
Mar 27, 2014 | Ibanez Talman Acoustic/Electric Guitar
The input cable fits into the guitar but it won't stay put, it just slides out as if it were too small.
Pro's loop the cable through their belt or guitar strap to avoid cable pulling out or twisting and wearing the connector.
Aug 02, 2011 | Silvertone Revolver - SS11 Electric Guitar...
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Hello, I have found that Ibanez AEL20 guitars' 5AEQ45F (SRTn) preamp-tuner has a 6V voltage, my AEL20 guitar came with 1,5 V batteries (3V in total). There is no internet source to get the...
There is little data on the internet about this... However my AEL20E uses 2 AA cells. Some older ones may have used a 9 volt battery. Yours should use the 2 AA cells which go into the box right by the XLR output plug.
Feb 16, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
My tuner shows a green flashing light, the battery is new, even checked it with another one. No matter what i do it just shows a green flashing light. picking the strings for sounds makes no difference at...
Often, the flashing green light indicates that the tuner is NOT receiving a signal and is a warning that the tuner is turned on.
First thing is to check if you have normal output from the guitar from the pickup. If the output is normal, there MAY be a failure in the tuner.
ALSO, just because a battery is new doesn't mean the battery isn't depleted... either try another from a different batch or use a voltmeter to check it. I have seen people chasing their tails due to a brand new bad battery.
When you select the tuner does the audio OUT of the guitar cut off as it is supposed to?
Sep 03, 2010 | Washburn D10sbc Acoustic Guitar
Fuse - 2amp for a Silvertone 1472 Amplifier
Hello endaya try www.digikey.com if you are using a 2amp buss fuse, its available, 117V is applicable to 220V, just follow the amp rating.
Apr 22, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Feb 20, 2010 | Music
Music Logo
41 people viewed this question
Top Matrix Music Experts
Vito Vacirca Jr.
Are you a Matrix Music Expert? Answer questions, earn points and help others
