Question about Yamaha RX-V663 Receiver
I have just completed running the automatic speaker setup program 4 times. Each time it has given a warning message that two speakers have their wires reversed. I have checked the wiring terminals and tightened the wires. The wires are not reversed. During the setup the sounds seem to be the same over each speaker. What should I do? Thanks Martin Bates
  • blueextc3221
    blueextc3221 May 11, 2010
    Do what it says and reverse the wires.
    They may have been made on a friday :)
    The wires in the speaker may have been reversed.
    Give it a try and re-post results.
  • 336 Answers
Check both the phase and position of the speakers. Phase is that the speaker wires are positive is to positive and negative is to negative from the receiver to the speaker. Then check that the speakers are in the proper place in the room,( front left is in the front on the left side when facing the TV).
Posted on Jan 11, 2009
Loud Speakers only have 1/4 inch inputs
Get the Speakons to 1/4" cables. If you're concerned about grounding, make sure the amp is turned off before plugging or unplugging the speakers.
May 02, 2017 | Music
Sometimes my laptop recognizes my cam and other it doesn't
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function
properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as
follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and
Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
(http://www.soft32.com/download_30.html )
set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the
4. Next go to the Test Audio section and (in blue writing) click on “Open the call
setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on
top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.”
And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or
friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and
video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window.
If you are currently participating in an AOL Live Video IM session, a message will display:
You must disconnect the current AOL Live Video IM conversation before running setup. Would you
like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers
and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to
first check your audio and video settings? Click the Yes button. The Audio and Video Tuning
Wizard will appear to help you verify that your camera, speakers and microphone are working
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may
appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will
cause the drivers to be corrupt and render the camera unusable till reinstalled it properly.
Hope this helps. Bud
Feb 09, 2010 | Logitech QuickCam for Notebooks Pro...
Ive downloaded the software from microsoft, but when i try to run it, it says "setup did not complete downloading and installing files to your computer. please run setup again to continue this process" so...
Save your downloaded software to the hard disk.
properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
see and her to you.
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Dec 21, 2009 | Microsoft LifeCam VX-1000 Webcam
Trying to install software for my Kross webcam.
properly.
A. Skype Setup:
see and her to you.
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Nov 04, 2009 | Computers & Internet
How do i connect muh webcam through aim?
Normal 0 See section D. AIM AOL Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
http://ca.messenger.yahoo.com/download/
After downloading and installing Yahoo Messenger set it up as follows:
1. Click on Messenger at the top left and then go down to Preferences and then the Preference Window will come up.
2. Next click on Calling and Devices. In the Calling & Devices on the right and set the Microphone and Speakers to the computer Audio Card or sound device installed in the computer.
3. Just below that, go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
4. Then after completing the Audio Setup, on left panel, go to down and click on Super Webcam and click on Start Super Webcam Mode Automatically.
5. Then click APPLY and then OK.
6. Next click on MESSENGER and then click on MY WEBCAM and you camera should BRODCSAST and you will see your picture.
http://dashboard.aim.com/aim
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
Microphone
Speaker
Camera
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Jul 17, 2009 | Logitech QuickCam Communicate STX Personal...
My web cam shows black screen on broadcasting time on yahoo messenger.but in windows and skype messenger it shows correctly. my web cam is a4 tech pk750.what can i do?
See section B. Yahoo Messenger in the info below to setup the Audio & Video.
A. Skype Setup:
B. Yahoo Setup:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Microphone
Speaker
Camera
Notes:
Jul 03, 2009 | Computers & Internet
I have an Acer 5920 laptop with integral webcam which isnt working - i use it to chat on msn with friends and every time i try it it always says "camera busy". I dont have any othe programs open. I think...
See section C. Windows Live Messenger in the info below to setup the Audio & Video.
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Jun 22, 2009 | Computers & Internet
PC blocks when i try to "complete" the instalation of my E3500
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Microphone
Speaker
Camera
Notes:
Mar 14, 2009 | Logitech Webcam
No sound on my computer
FIRST try the simple solutions. Check if your speaker wires are plugged into the proper ports.
If you are unsure, it won't hurt to try different configurations.
(If you hear sound from other devices such as playing a CD or the "Microsoft Sound" when starting up or shutting down, then the speakers are wired correctly.)
If this is OK then try...
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Sound video and game controllers"). If there is some kind of a yellow "Warning" icon superimposed on the 'speaker' icon there is your problem! Missing or corrupt drivers.
If no "Warning" icons then try...
Click on the blue icon on the second row, (it looks like a large key in front of a monitor) that says "Scan for hardware changes" when you hover your mouse on it.
One at a time...
Double click on each of the devices that have 'Audio' in the listings.
Click the "Properties" tab; look for any "Warning" icons.
Uninstall the DRIVERS for THAT DEVICE only. See instructions below.
Click on the faulty device and hit the "remove" button, follow the instructions given by the program.
(This uninstalls the DRIVERS)
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Nov 12, 2008 | Dell Inspiron 6000 Notebook
No audio when i try to play tunes in itunes
(If you hear sound from other devises such as plating a CD of the "Microsoft Sound" when starting up or shutting down, then the speakers are wired correctly.)
Go to your "Device Manager" (Right click on  'My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Sound video and game controllers"). If there is some kind of a "Warning" icon superimposed on the 'speaker' icon there is your problem!
One at a time...
Double click on each of the devises that have 'Audio' in the listings.
Click the "Properties" tab, look for any "Warning" icons
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Oct 23, 2007 | Adobe Photoshop 7.0 for PC
Yamaha RX-V663 Receiver Logo
161 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
