Question about Epson Stylus 1400 InkJet Photo Printer
How to fix my printer progress meter
My printer ink level dont show the colors, so i have no idea which one should i replace when they are empty...Can someone help me .??
Go here and download monitoring software so you can see ink levels. Hope it helps.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?sku=C11C655001
Posted on Jan 26, 2009
My printer is not HP it is Brother MFC-260C
The printer uses several ways to show ink levels. When you replace the cartridge it askes if it has been replaced, Say yes and it sets the ink level monitor to full. As the cartridge empties it them checks through an electronic eye system through the cartridge. When it cannot see any ink it says it is empty.
Replace the cartridges and it should fix the problem.
Feb 22, 2016 | Brother MFC-260C All-In-One InkJet Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Canon printer wont print colored how to reset chip
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn off level on black cartridge) and color copy (for turn off level in color cartridge). The printer
shows empty cartridges but it will printing.
Nov 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My father received the "replace ink cartridge" message on his Epson NX400. He replaced the black cartridge and now it says to replace "cartridges" (s). He didn't replace anymore because he didn't have...
Epson printer only work if there are all ink tank installed, and one of them not reach zero ink level (ink out in program). After replacing black ink, may be the other ink tanks reach zero level, so message to replace ink tank appear again. You can use the used ink tank (by refilling) if you don't reset ink level counter. Better you use the CISS ink tank (with or without outside bottle), that have autoreset function.
Oct 18, 2009 | Epson Stylus NX400 InkJet Printer
I refilled the ink with a refill kit
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn of level on black cartridge) and color copy (for turn of level in color cartridge). The printer
Oct 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My mp150 wont let the paper feed into it & the b & c lights are continually flashing any ideas
The ink cartridges are empty.Replace them or press
consistently button for black copy and button for color copy.This will disable the function of the printer to show ink levels and you will continue printing so long as the ink finally over.
Oct 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
My printer can't read the new ink level after refilling
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Dec 06, 2008 | HP DeskJet F4280 All In One Printer InkJet
Canon MP460 cartridge error
"Verify that you are using Canon(TM) cartridges. The technology has progressed to where they have modified the ink to be identified by their printers. You cannot currently use refill cartridge inks to refill Canon cartridges. If that is not your issue, then try removing and replacing the cartridge(s)and reset the ink level indicator.
Lets hope for the best!
Regards,
Eagle"
Honestly.. There is absolutely no way for Those Canon printers to "look inside" or "Detect" the formulation of ink inside the cartridge...
Canon CL-31, CL-41, CL-51, CL-52 Print cartridges have the highest electronic _Failure_ rate of anything other inkjet cartridge on the market. Canon is aware of this. Replacing the Cartridge is the only sure-fire way of fixing this.
*sometimes the printer will tell you its the color cartridge, when in fact its the black cartridge. its advised to replace them both during these error messages.. it'll save you a trip, and the customer service rep's head. haha"
Using an Aftermarket or "re-filled" canon original cartridge is a sustainable resource for anyone looking to re-use an end-user item, and save money in this "tied-selling" market.
I proved you wrong by replacing my inkjets with Oringinal Canon PG-40 black, and CL-41 color cartridge. I ran them until they were empty. Bypassed the Ink Metering System explained to me through the canon software provided during the printer installation, and continued to print with them until they were 110% bone dry empty, laying absolutely no ink on the page. this took approx. 3 hours from perfect start, to finish.
If "canon printers have progressed so much as to distinguish formulations of ink" then.. this canon sure was the PICK of the litter. it continued to print *** as the day it was purchased, while not laying a single droplet of ink on the page.
get a life. stop dissing the aftermarket with your un-supported facts!
reguards,
inkjetech_007
Oct 10, 2007 | Office Equipment & Supplies
Epson Stylus  1400 InkJet Photo Printer Logo
64 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
