Question about Weber Grilling
Losing flame< I have a master forge L3218 , 5 burners , all was well till last time I used , and whe I ignite the 1st burner all is , the after each additional burner the flame continues to dwindle
I have cleaned the burners and burner box, as I said if one burner is lit all is well , as I light the others flame reduces.
TheMobilian
  • 8220 Answers
SOURCE: Loss of pressure on Kenmore 16322
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
Posted on Dec 17, 2008
SOURCE: Low flame
Solution #1 is correct. If your regulator is / was good, then you would most likely have a leak in a line or fitting - and the regulator has properly restricted or stopped gas flow as it's designed to do for obvious safety.
However a very common leak is the main plastic tank coupling which renders the whole regulator and hose assembly useless.
Quick fix, go to Wal-Mart and buy a $20 replacement regulator which comes pre-fitted with hoses and couplings. Get the dual or single hose depending on whether you have a side-burner or not.
Voila! Your good to go a few more years.
Posted on Feb 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Only enough gas flow for 1 of 3 burners
Shut off the tank and remove it from the grill. open all valves. close all valves. Reconnect tank to cooker and SLOWLY open the valve a hair. Then retry.Something in the dang newer safety tanks cause this phenom.
Posted on Mar 22, 2009
  • 10 Answers
SOURCE: One burner has low flame
Try looking for webs back to where the burner tube meets the valve. Otherwise you need to remove burner tube to access back of valve to clean with a torch tip cleaner or compressed air, (remember to disconnect grill from gas source first) inside valve orifice.  Usually the back of valve can be removed with a wrench. Worst case you always get a new valve off internet if you can't resolve the plug. Hope this helps, good luck.
Posted on Mar 29, 2009
SOURCE: cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
Posted on Oct 13, 2009
After all 5 burners ignite, one of either outside burners will flash out and blu flame licks upward.
If you have 'inshot' burners or the standard old 'ribbon' burners, there could be little wings on the sides of the burners that are responsible for spreading the flame from the igniters location to the burner next to it. I would think the two outside burners need to be 'tweaked' a tad bit either clockwise or counterclockwise to align better the little 'flame-spreader' wings. Some older ones ignite the burners by use of a 'zip-tube' which carries the igniting flame across the top of the row of burners to light them in a 'blanket' pattern. This style was typically the old 'atmospheric' burners and not the ones with combustion air fans.
Jan 01, 2015 | Heating & Cooling
Hi, We have a GE profile cooktop (JGP975SEK1SS ). Last night, the boiling water spilled on the bottom right burner, so I turned off the stove. But since then every time we turn on the stove, the two...
Hi shadnaz,
A common issue with water causing the problem. I'd suggest following my below Tip on fixing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 | Cooktops
First burner ignites quickly, second and third take up to 3 minutes IF they fire at all. burners are not clogged.
If the first burner's flame characteristic's look right, the remaining burners need to be removed and the venturi valves and burner orifices checked for obstructions and cleaned if necessary.That's generally the cause of delay ignition.
Hope this helped and Happy Grilling!
Mar 20, 2011 | Char-Broil CharBroil Master Flame Gas...
I have an americanaire ultra sx 80 furnace that if it does start up the 1st time, the induction motor continue to run and it will not start
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Jan 04, 2010 | Heating & Cooling
My 8 yr old Goodman heater will ignite for 10-20 seconds then cut off, and then attempt over and over. Leaving our 2 bdrm condo cold. It did this last year, and all we had to do was change the filter. I...
Sounds like a flame sensor issue. It may just need to be cleaned. It is located either far right or far left in the burner box and has only one wire going to it. It will be in the flame of the last burner. If the flame can't get to it in a very short time the computer shuts the burner down. Make sure all burners are clean. You can use a can of air if you are careful near the igniter, it is very delicate. Here are some other ideas.
Dec 29, 2009 | Goodman Heating & Cooling
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
WILL NOT LIGHT ALL 5 BURNNERS WILL ONLY LIGHT 2 THEN SHUTS OFF GOES TO LOCKDOWN
Nov 23, 2009 | Coffee Makers & Espresso Machines
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Swooshing sound in oven when burner ignites
the valve your talking about with the two wires on it is the safety valve and should not let gas in without the ignightor being on sounds like its leaking i recommend shutting the gas off till the valve is replaced there is no piolet light on theese ranges
Jan 18, 2008 | GE JGBS23 Gas Kitchen Range
Grilling Logo
42 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
