Question about Coffee Makers & Espresso Machines
Rocket cellini espresso leak
Leaking water when under pressure
SOURCE: Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Posted on Sep 30, 2007
  • 4 Answers
It is normal for a small amount of water to come into the driptray after each coffee brew. This is the pressure releasing from the brew unit. After a while coffee grouts will build up in the bottom of the slot where the brew unit slides on to the valve. (you see this slot when brew unit is removed), Get a small thin wire to poke in the hole and gently pour small amount of water by hand to clear any blockages.
clear water leaks from under the m/c can indicate leaks ffrom the teflon joints and/or steam valve assy. Some early machines had plastic steam valve assy's and leaked like mad. New stainless steel ones are fitted now.
hope this helps
Posted on Apr 11, 2008
EsWorld
  • 1618 Answers
SOURCE: frothing valve leaks water when not in use
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Posted on Feb 27, 2009
  • 14 Answers
SOURCE: Starbucks Barista Espresso Maker
This is a general comment for people having problems with leaks and pressure in their espresso machines. If you do not used filtered water, the minerals and other materials suspended in the water will bond to the moving parts and tubes of your machine (e.g.: scale). The problem will be worse if you live in an area with particularly hard water. In some cases the pressure pipes can get completely blocked and if the pump is powerful enough, the pipes can rupture, otherwise, the pump will simply not put out any water. The solution is to regularly flush out the system with descaler. The frequency of cleaning depends upon how often you use the machine. You can get descaler from any decent coffe place (like Starbucks), an appliance repair place, or the hardware store. I use CLR which is sold at hardware stores. CLR stands for Calcium-Lime-Rust, and it effectively cleans all of these and is cheaper than specialty scale removers. Simply dilute some in water and pour the mixture in the machine, then cycle the pump and run it through. Collect the spent liquid and run it through again 4 or 5 times (or more if you've never cleaned your machine before...) Allow the liquid to sit for 10-15 minutes between flushes so that the solution has a chance to eat away at the scale. Once you have done this a few times, flush out the machine thoroughly with clean water 4 or 5 times, using CLEAN water each time you rinse. If you want to get an idea of the scale that has been removed, keep a small amount of the original clean solution in a glass and then compare the spend cleaning liquid with unused cleaning liquid to see the difference. The spent liquid should be foggy/muddy compared to the clean stuff and if you let it sit, the scale will settle to the bottom of the glass and will be clearly visible. You can prevent some of the buildup in your machine by using filtered water as they do at Starbucks.
Posted on Jun 05, 2009
SOURCE: Sirena espresso machine leaks water from under the
It's the hose from the steam boiler to the upper boiler. Part number 16000190 Silicone Tube 4,2X8,2. It is the same tubing as you would find on a fish tank with a red woven cover - I guess to prevent leaks. I cut out a short section that had developed a hole because it is not designed for the heat and pressure, but it shortly started to leak again. The tubing is not the correct kind for this purpose.
Now i am trying to find where to get a replacement tube without having to send it off someplace.
Posted on Sep 10, 2009
Leaking water under the drip tray
First, be sure to regularly push a straightened paper clip in that nozzle! It can get clogged with coffee grinds quite easily.
Then call Sunbeam and tell them you want the waste chute extender. It's a little plastic tube that fits over the nozzle to extend it further into the drip tray. Truth be told, you could probable push a 2cm piece of 3mm aquarium pump air tubing over it.
May 22, 2013 | Sunbeam Coffee Makers & Espresso Machines
My Espresso Machine leaks out the bottom
thier is a puddle of water that leaks out of the bottom of machine after i brew my expresso
Dec 29, 2012 | Mr. Coffee ECMP40 Espresso Machine
Krups xp 4050 leaks water under unit when sitting on counter
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Jun 13, 2010 | Krups Small Appliances Espresso Machine
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Espresso machine rubber ring tear causes water leak
hi may i know whether Electrolux Pump Espresso Model EES200 can make single shot of espresso? Cos I tried but the machine only make 1 cup of coffee. Please help. Thank you
Sep 09, 2009 | Electrolux Coffee Makers & Espresso...
Sirena espresso machine leaks water from under the tank slowly. I can't seem to find the source of the leak but I didn't take the machine apart either.
Aug 16, 2009 | Saeco Starbucks Sirena Espresso Machine
Water leaking under the tank
If the water is coming from under the cold water tank on the back of the machine it probably the o-ring seal in the grey machine recepticle which is visable when you remove the tank for filling. This seals the tank to the machine body and over time can leak (mine has!!). You can get them from Gaggia UK in Halifax
Dec 24, 2008 | Saeco Magic De Luxe Espresso Machine
While making espreso, the machine leaks water from underneith.
Please email me with your request and I will send you info to fix it.
irene@smithagy.net
it is basically info on removing coffee oils from the Brew Head Screen.
if that does not work you can contact the service center at phone 201-439-1700 or email:
info@electra-craft.com
www.electra-craft.com
Thank you.
Nov 17, 2008 | Briel Domus Due Espresso Machine & Coffee...
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
139 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
