Question about Refrigerators
I have a kenmore 596.79213013 refrigerator less than 2 years old with significant ice build up on freezer floor. need to remove almost daily. Any ideas how to fix? owners manual is not helping
Ice build up on freezer floor
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
SOURCE: maytag side by side, bottom freezer compartment had daily ice build up
I had the same problem with mine a couple of months ago. There is a drain which gets plugged. You have to remove the contents of your freezer, and then look at the back area of the freezer. The panel that's on the back is removable. Once it's removed, you will see a drain at the bottom. Mine was clogged up with debris, and was covered with ice. I poured warm water over the drain, soaked it up...did this a few times to melt the ice, then I worked at cleaning out the drain. Mine wasn't plugged too badly, I ended up having to blow air through the drain using my air compressor, to be positive that it was clear of debris. You could poke something down the drain, but it won't go very far because there is an elbow on the drain tube(visible on the backside of the unit itself)
If you get it cleaned out, it should be fine. Mines been great ever since I cleaned mine out...no more puddles on the floor.
Posted on Feb 18, 2008
aborcass
  • 2651 Answers
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Posted on Dec 14, 2009
  • 66 Answers
SOURCE: Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Posted on Jan 29, 2011
Ice build u p and leakage in freezer
you have a blocked drain in the freezer,when the machine goes into defrost the heater comes on and melts the frost off of the evaporator coil,the water melts and goes down the drain hose under the coil and leaks down to a drip pan near the compressor where it evaporates from the heat,your drain is blocked and the water is leaking onto the freezer floor and will drip out onto the floor,i use a steemer to blow out the drain line,shut down the machine or unplug it,melt out all the ice with hair dryer,depending on your model you might have to remove the back inside wall of the freezer to get at drain hole,you need something to push the **** out the drain hose,you can try a turkey baster or air from a compressor or a shop vac set it to blow,when you think it's clear pour a cup of hot water into the drain,if it drains down you're done if not keep hitting it with heat and air to push it through.
Sep 01, 2012 | Refrigerators
Kenmore Elite ice maker doesn't work
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting.
If it still exists then there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Sep 25, 2009 | Kenmore Refrigerators
Ice build up on freezer floor.
Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
Thanks
Vic
May 22, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator Mod 70162990
It is under the evaporator you will have to remove the back cover... let me know if you want to do it and I will step you thru it...
Sep 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
Water leaking onto floor
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Water leeking on floor
most fridges and freezers have a small outlet hole at the very back of the inside make sure this is clear should have a small tub at the back of your appliance on the outside try this
Aug 15, 2007 | Kenmore 62232 / 62234 / 62239 Bottom...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
