Question about Kenmore 17259 Free-standing Dishwasher
Kenmore dishwasher this dishwasher is keeping water in the bottom after the final rinse. i have blown air back thru both ways of the drain and it seems to moving good but it does not drain completely. there is a little rubber flap that i have not decided where it goes now. can you help me. rick
  • Anonymous Mar 13, 2014
    wont go to final spin took the hose off the pump and found a orange rubber flap that is broken would this be why it isnt go thru the final spin cycle
  • 3 Answers
The water that remains after the final rinse is normal and serves to keep the seals lubricated. This is a normal function of the dishwasher.
Posted on Jun 09, 2007
Is there a filter in Kenmore Dishwashers that need rinsing or changing? Our dishwasher seems to be backing up, leaving "silt" on the dishes. I empty the screen on the door, but residue has built...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Apr 22, 2011 | Dishwashers
Doesn't drain on final rinse cycal, leaves 1" of clean water in bottom of machine.
Make sure your drain hose is attached securely to the underside of counter/sink area. If you have a air/gap, make sure it isn't clogged. Both will cause water to backfill back into the dishwasher especially if you're garbage disposal is clogged or restricted.
Rich
Western Appliance Repair
Appliance Repair Eagle
Oct 09, 2010 | Frigidaire 24 in. GLD2150RCC Built-in...
Soap in JetDry dispenser.
Unfortunately there is no easy way to completely get the detergent out of the rinse aid reservoir in one quick method, short of taking the inside panel off the door.
However, I would try a simple way to flush it out. With the door open almost al the way open, pour warm/hot water into the rinse aid fill hole and keep pouring until you start to get clear water coming out. The water will be flowing back out the fill hole you're pouring the water into and should just flow down the door panel into the dishwasher tub. Try to keep the door about 10-15 degrees up from all the way open to let the water get in the rinse aid reservoir.
Just pour the water in slowing so you don't agitate the mixture and you should be able to get it running clear in 5-10 minutes. It could take a gallon or so of warm/hot water to accomplish this, but it will flush it.
When you'r done, just put the dishwasher into a rinse cycle to pump out the water and soap, etc. You may have to run a full cycle afterwards to get rid of any excess detergent in the tub.
Hope this helps and best regards!
Aug 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
May 01, 2009 | Kenmore Dishwashers
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Jul 05, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Whirlpool Dishwasher DU850DWGX1 won't completely drain
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
May 02, 2008 | Whirlpool 24 in. ADG6340iX Built-in...
Kenmore Dishwashing not working properly.
First off check to see if the drain hose is clogged where it meets the sink drain. 9x out of 10 this is the problem. Then remove the grate cover for the drain under the bottom rack at the back of the unit and check for lost utensils, broken glass, food residue, etc... If these are fine, then it sounds like a clog in the drain line at the water pump or a possible problem with the water pump, as long as it IS cycling right and there are no missed steps along the way (i.e. the last drain cycle before the rinse doesn't kick in and therefor uses the wash water as rinse water). The water pump is under the unit, so you will have to pull it out of it's hole. Remove the bottom panel under the door, remove the box cover on either the right or left hand side AFTER YOU FLIP THE BREAKER FOR IT and remove the wirenuts and free the line from the unit, and turn off water valve under the sink and unhook from the solenoid valve under the unit, and finally remove the drain again from the sink. Pull out of hole by finagling and sheer willpower LOL making sure you stop every once in a while to feed the drain hose back through the hole in your cabinet. You will have to split (take apart) the case of the water pump after you remove it from the unit and check the impeller for wear and to make sure it creates a good seal against housing and make sure the diverter engages properly and diverts water to the specified port (wash or drain) in the correct cycle. You may have to use an old extension cord, cut off the receptacle and hook up wires so you can work this outside. Should cure up any problem. Hope this helps.
Jan 27, 2008 | Dishwashers
Dishwasher 16719 problem
plugged air gap line most likely. open air gap and remove small dome so that the water can pump out directly to the sink, putting a towel behind it to keep the water off the counter. when clear, put it all back.
if that is not it, your pump is bad.
good luck
mark
Dec 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 17259 Free-standing Dishwasher Logo
159 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
