Question about LG W2234S 22" LCD Monitor
Lg w2234s faults
No desktop signal, only lg logo
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: LG W2234S restarting every 3 minutes
I will assume that you have already try this monitor with other PC with the same result, and also try new VGA cable with the same result, otherwise you will have to open it up and o some inspection inside the monitor.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Posted on Mar 30, 2010
  • 30 Answers
SOURCE: lg w2234s no signal?
shut down the computer completely by pressing on the power button until no sound is heard. Then make sure that the screen is properly connected to the computer and turn on the computer. If this doesn't help, disconnect the cable that connects the screen with the computer, see that the connection looks fine (no broken pins) and then connect again to the computer.
Posted on Oct 04, 2010
W2234s lg
http://www.retrevo.com/support/LG-W2234S-Monitors-manual/id/23240bh035/t/2/
CAN THIS BE THE MANUAL ? .CAN'T FIND ANYTHING ELSE.
HOPE IT'S RIGHT.
Jun 19, 2013 | HP 2011X 20 inch LCD Monitor
Looking for driver for lg w2234s
Hey you should be able to get the driver at - www.LG.com
Nov 17, 2011 | LG W2234S 22" LCD Monitor
Lg w2234s keeps turning itself off, all cables ok so is video card, any ideas
try pressing on source key, the monitor has two input sources one digital and one analog maybe it's on the wrong input (digital connected while monitor on analog or vice-versa)
Oct 14, 2011 | LG W2234S 22" LCD Monitor
How do I get my LG W2234S out of power saving mode?
The mcu on your main PCB ( vga input) has most likey become corrupted. A replacement card would solve the problem.
the service manul has a step by step guide to fault finding
http://elektrotanya.com/lg_w2234s-sni-bni-axx-qp_sm.pdf/download.html.
Manufacturer Part Number:
EBU59489401
Board Numbers: 791501300700R
assuming tried different cables and pc's already
Nov 16, 2010 | LG Flatron W2243SPF Widescreen LCD Monitor
Lg w2234s no signal?
Oct 04, 2010 | LG Flatron L1715S 17" LCD Monitor
Mar 29, 2010 | LG 22" FLATRON LCD Monitor
LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Oct 29, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
May 26, 2009 | LG Flatron L1750S 17" LCD Monitor
Moniter transitions to LG logo
Check the cable and make sure it is plugged in securely at both the monitor and PC. If the cable is connected properly, then the problem must be in the monitor itself. You could try setting the input mode manually on the monitor - the default should be auto - you could set it to VGA or DVI whichever your case is and see if it helps.
Jan 22, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
LG W2234S 22" LCD Monitor Logo
19 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
