Question about Hardware & Accessories
I cannot figure out setting for utilitech model SP-035
I can set the clock with no problem. Timer for weekly setting 5PM to 10PM ??
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: intermatic timer T101
This link should help you set timer.
http://www.intermatic.com/images/instruction_sheets/T101.pdf
Good Luck and Please Rate FixYa!
Posted on Feb 27, 2009
jyackle5
  • 8197 Answers
SOURCE: i have a new utilitech
Would like to know if you have got the timer to work
Posted on Oct 22, 2010
I dont no how to set the timer to 24 hr clock
change to 12 clock
however a 24 hour clock has the same times up to midday -- midnight to midday --- the hours are 1 to 12 oclock after midday you take 2 off the reading and it is the same time as a 12 hour clock
so 1300 is 1 o'clock, 1400 is 2 oclock ,1500 is 3 o'clock
1800 is 6 o'clock 2400 is midnight
the minutes are the same regardless so 1.30 is 1.30 after midnight or 1330 after midday or 1.30 after midday now for example --if you want the timer to start at 6am you set the timer to start at 6 am to switch off at 8 am set switch of at 8 am
it you want the timer to start at 6 pm set it at 1800 and switch off at 10pm set it at 2200 hrs
Jan 22, 2017 | Hardware & Accessories
Problem #1. On model #DT300 the instructions under Set Time of Day # 3 does not change the day. The only place I can get the day/s to change is under the programming. What is wrong with it. I have...
Thank you for very clear question, and timer identification.
1) I don't have repair for defective timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
2) Choose DT300 format
#3 says to press-and-hold CLOCK button until display shows 24H or 12H
Then release CLOCK button.
Next press HOUR button to select either 12H or 24H
This lets you choose am-pm format -or- choose military-time format where 11pm is 23
3) Set current time
Press-and-hold CLOCK button throughout whole current time setting.
Do not release CLOCK button until current time settings are finished.
Next, press HOUR button, and then MINUTE button, and then DAYS button until current hour, minute and day display.
If this step does not work, then timer has gone bad.
Replace with locally available Utilitec 155671 from Lowes or Westek TE06WHB from Target
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
4) How to set DT300 timer program for full week of operation.
Each program requires you to set program 1 ON time and program 1 OFF time
Be careful to avoid program conflicts and overlaps so timer works as expected.
For program 1 ON time, you press PROGRAM button until 1 and ON display.
Release Program button.
Then select hour, minute and days. In this case you want all days of week, so you keep pressing DAYs button until whole week displays: Mo Tu We Th Fr Sa Su
Then you set program 1 OFF time, you press PROGRAM button again until 1 and OFF display.
If you set ON time for all days of week, and OFF time for Tu Tuesday, then timer will not work correctly.
5) Read manual and add a comment for additional help
Aug 18, 2011 | Hardware & Accessories
I lost the instructios for Raindrip Water Timer R672C
The start time on these style of timers is whenever you set it. So if you want it to run at night it needs to be set at night, e.g. turn to off/reset, then at 10pm go set to the freq. and duration desired, then it will run at 10pm. Also note this timer waits a full cycle to run the first time after it is set, e.g. if today you set it to run weekly, the first time will be next week.
Jul 03, 2011 | Hardware & Accessories
I am trying to st the timer to turn on at 5PM and turn off at 11PM.
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
http://waterheatertimer.org/pdf/hb88rc.pdf
HB88RC programming Instructions:
Install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 5pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
Dec 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
Installed the timer last week, we have it to cut on at 4pm and shut off at 10pm, it will come on at the right time, and even shut off at the right time, but for the first time only, once it hits the 10pm...
Your clock motor is not correctly wired to the terminal block. Carefully review the connection diagram for the line and load leads and the timer clock leads. Somewhere in there you made a mistake when connecting the wires. If not there is a defect in the clock mechanism and you should replace it. For warranty information please refer to the instructions or the place you purchased it from for assistance.
John
Dec 14, 2010 | Intermatic WH40 - Water Heater Time Switch...
Intermatic EH10: I can't figure out how to set a schedule of Sun - Thurs, 8am on, 10pm off and Fri & Sat, 8am on, 11pm off. I tried every day of the week 8am on, 10pm off and Fri & Sat 8am on, 11pm...
http://waterheatertimer.org/pdf/eh10-manual.pdf
The EH10 is 120V digital timer.
The timer offers the following days:
-All 7 days
-Monday thru Friday
-Saturday and Sunday
-Each individual day
-Blankday (day skipper)
If I understand your schedule:
You want
Program1 ON at 8am Sunday
Program1 OFF at 10pm Sunday
Program2 ON at 8am Monday thru Friday (with blankday on Friday)
program2 OFF at 10pm Monday thru Friday (with blankday on Friday)
Program3 ON at 8am Friday
Program3 OFF at 11pm Friday
Program4 ON at 8am Saturday
Program4 OFF at 11pm Saturday
I filled in the chart for you.
I left off the display.
I do not have this timer and don't know 100% how the display looks without buying the timer.
If you need more help on a specific step in the manual, add a comment and I will answer.
Nov 07, 2010 | Intermatic 7 Day Electronic Timer Eh10...
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
How to set start time on timer raindrip r672c
Jun 29, 2009 | GARDENA Water Timer #31169-4
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
Hardware & Accessories Logo
643 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
