Question about Watches
How do you adjust the size on the Invicta model 5738?
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
What size battery does an invicta reserve model 12018 take
Take your watch to a jeweler who will identify the type (not size) and may even replace it for a nominal sum.
Dec 23, 2016 | Invicta Watches
What size battery for invicta model 12843?
  • Remove back
  • Find battery
  • Identify type
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery.
Nov 28, 2016 | Invicta Watches
I need screws for invicta subaqua noma 3 band model # 6510
Good day I had purchase parts direct from Invicta and found that is easier then looking around for the parts here is the info;
Message Invicta Customer Service . Mon - Fri . 9am - 5pm EST
Email service@invictawatch.com
Call 800-327-7682 . Mon - Fri . 9am - 5pm EST
Fax 954-921-2508 or 954-862-5461
Write Invicta Watch Group
Attn: Customer Service
One Invicta Way (3069 Taft St.)
Hollywood, Florida 33021
U.S.A.
#PS
or you can also check them at their web-site http://invictawatch.com most parts are really low cost with the exeption of the mechanic parts
Apr 17, 2012 | Invicta Subaqua Noma Iii S
GOOD EVENING, I HAVE AN INVICTA RS8 LIMITED EDITION RUSSIAN DIVER. I WOULD LIKE TO GET INSTRUCTIONS REGARDING ADJUSTING THE WRISTBAND. THANK YOU
ok if u mean sizing the watch ok veyry easy just pinch 1 side of the link where u are sizing and with a flat head micro screwdriver un screw opposite side now i would so this to all screws as they get very loose in normal wear put a lil bit of lock tite on eack screw and put back 2gthr after u have sized it hope this helps i have an rs8 took me less than 5 min to do 2 watches green and purple
Nov 05, 2010 | Invicta Watches
Watches Logo
14 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
