Question about Ovens
AEG Double oven Model D8800-4-M The on /off button was stuck and now has broken . How can i fix this?
The button was sticking and now it has broken off and I need to replace it . Apart from this the oven was working well. Can I buy a new part for it?
  • 139 Answers
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
SOURCE: AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Posted on Sep 15, 2008
SOURCE: how do i remove a built in oven?
i need audio driver intel D945gcnl
Posted on Feb 16, 2009
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
  • 572 Answers
SOURCE: oven seems to work but the display panel dark.
Posted on Feb 11, 2010
Where is the model no on our aeg white double oven competence about 8 years old
Open the door, usually engraved within the door panel. Either on the sides or Top.
Most important number is called the PNC. If not found there, look for a sticker on the Oven Cabinet upper, after opening the door.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | AEG Ovens
The glas bulb cover at the top of the grill/top oven has broken leaving the glass edge stuck in the thread. I have a replacement but cannot get the old remnants out. Do I have to call an engineer to...
take a wooden stick about the same diameter as the broken bulb; place a washchoth over the end; push the stick into the bulb base in the oven and, turn the stick counter clockwise until it comes out. the stick is an insulator so you won't get shocked and, the cloth grips the bulb base.
Jul 31, 2010 | Bosch HBN 9061 / HBN 9021 Double Oven
Broken glass AEG hob
If it is just the edge of the corner glass not a lot you can do if it is broken nearer the inside be very careful as the weight of pans can cause the break to spread.Check serial no. on base of hob body the first 2 digits are the year and 3rd digit is weeks in year.For example 92800055 that would be 2009 and 28th week equals july 2009.Any AEG unit has 2years full warranty.Check and you might be able to claim new glass.Hope this helped.
May 05, 2010 | AEG D2100-4 Electric Double Oven
Aeg oven model d2100-4-M wont work .
in what way- just taken ours to bits and fixed it
Mar 13, 2010 | AEG D2100-4 Electric Double Oven
Ge profile performance double oven. getting an F7
F7 is a stuck keypad/button.
Push all buttons at random several times each. This will sometimes un-stick a stuck button.
If that does not work the keypad control will have to be replaced.
Jan 16, 2010 | GE Ovens
AEG U7101-4-M Bottom oven not working
had same fault its a temperature switch at back of oven, you have to remove panel and is located half way up on left and has two spade terminals coming out the back.
Oct 28, 2009 | AEG U7101-4 Electric Double Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Jan 04, 2008 | Ovens
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
