Question about Daewoo Televison & Video
My wires have been cut where my radio should go
Can you help me i need to see a wiring diagram for the daewoo matiz v reg so i can install my stero please help
Try here its a bit hard to get on http://bojo.hopto.org/Auto/
Posted on Mar 21, 2009
Excessive consumption of fuel of daewoo matiz and cutting off
Sounds like the Oxygen sensor in the exhaust may not be working effectively. Check the connections and wiring running to it. The Oxygen sensor only starts to work when hot so be careful. The sensor outputs a pulse of voltage when the engine is running. If the voltage output is steady then it needs replacing.
May 28, 2010 | 1999 Daewoo Lanos
Window wiper on a daewoo matiz
Buy wipers at a good national brand auto parts store and they will change them for you.
Jul 01, 2009 | 2000 Daewoo Lanos
Daewoo Matiz cranks but does not start
Does your your alarm ligth stay on when switch car on? If it does then ther is a problem with your car alarm system.
Under your stearing rack is a white box. Take it to your local car alarm dealer to get new car ship and get new ship melted in your key.
Mar 05, 2009 | 2000 Daewoo Nubira
Power steering for Daewoo Matiz
i have a Daewoo Matiz 2000. It doesn't have Power Steering although other models of Matiz came with Power steering. I want to know if a Power steering can be installed on my Matiz. If so, whom can I contact.
sreejith
Jan 22, 2009 | 2002 Daewoo Lanos
Daewoo matiz without radio code
I need radio code for my daewoo matiz 2001. serial no is PH600CY0156180 and model no 79RC600/95. I will be so thankful if anyone can send me code for that.
Nov 07, 2008 | Car Audio & Video
I need the colour wire description for a 2000 dodge caravan Im removing the the factory stero and installing after market stero and need wring diagram , what each wire is for ,speakers ,power etc.
HI.
In the caravan are 2 types of Radio.
1. Normal sound system.
1 Premium sound system.
Note: If you don't want to cut the original wires,
You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
Normal: colour of wires.
Pink = Battery voltage.
Red/withe = Ingnition Voltage.
Brown/red and Dark green. = Left front speaker.
Dark bku/red and Voilet = right front speaker.
Brown light blue and brown/yellow. = left rear speaker.
Dark blue/orange and dark blue white = right rear speaker.
Ground is a single wire behind the radio.
If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
OK... I hope this information work for you.
Thank you , For use fixya. Rate please.
Jul 17, 2008 | Car Audio & Video
Stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
May 22, 2008 | Car Audio & Video
Televison & Video Logo
167 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
