Question about HP Pavilion dv9000z Notebook
Charging led blinking
Pavilion pv4 battery wont charge but runs plugged in
    Novelist:
    Champion:
  • 233 Answers
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it
with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
Posted on Dec 04, 2012
SOURCE: HP pavilion zd8000, Battery not charging
The problems with the HP Pavilion (Particularly the ZD8000) are sadly well-known by HP. It's not a problem with the battery or the charger or anything you can easily fix. The problem is heat. If you search long enough, you'll find hundreds of people with three problems: 1) the battery stops holding a charge after about 8 months, they buy a new one and get the same problem; 2) certain keys stop working on the keyboard, they remove the battery and the keys work again; 3) permanent lines start to appear on the display and never go away.
Unfortunately, there is nothing you can do about these problems with the ZD8000, except stop using it as a laptop and ditch the battery. I have been problem-free since I ditched my third battery and just use it with a power cord.
Last year, I filed a formal complaint with the Better Business Bureau regarding HP's failure to acknowledge this problem and recall the machine. Each time I called service, I was instructed to follow the battery initialization procedure. All this does is allow support to get rid of you for 24 wasted hours, after which you have to call again and talk to some one new who tells you to do the same thing. The problem is, the procedure fails because the battery won't hold a chage in the first place. If you get to the end of the procedure with them after wasted days, they tell you to buy a new battery.
The HP ZD8000 is defective and never should have been released with a Pentium 4 processor. It's too hot and fries the battery and damages the screen.
Posted on Dec 08, 2007
thejus
  • 19 Answers
SOURCE: HP Pavilion DV1000 not charging the battery
yes its u r mother board battery connector problem...in the mother board there is IC for sensoring DC supply..near the battery connector..plase check the IC is working properly with A logic probe.if it not working plaese replace the IC with a blower..
Posted on Jan 19, 2008
  • 8 Answers
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Posted on Apr 28, 2009
  • 109 Answers
SOURCE: HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Posted on Aug 13, 2009
gsage
  • 180 Answers
SOURCE: HP mini wont turn on and power led blinking
Removed the battery - power it up from your a/c adapter then refit the battery -
Posted on Jul 08, 2010
Power indicator blinking orange and white
Mym7 stops charging the battery every now and then to allow the battery to discharge. This extends the life of the battery and changes the state of the battery light.
Feb 21, 2014 | HP Pavilion dv7-7000 dv7-7023cl B5R45UAR...
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Batery problems
what is the blinking led color?
  • if it does not come on at all the battery may not be having contact or the AC Adaptor not plugged in correctly.
  • if its Blinking red and wont charge then Battery is defective replace the battery. Battery can also be defective if the led light never turns green during charging
  • hope this helps pls do let me know
Apr 06, 2010 | Casio Exilim EX-Z750 Digital Camera
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Aug 13, 2009 | HP Pavilion zd8000 Notebook
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Laptop battery working
Battery led is blinking, this usually means your battery is faulty. Try replacing the battery with a new or tested second hand one.
Hope this helps
cheers
Feb 14, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
