Question about Kyocera Mita KM-2550 All-In-One Laser Printer
I have kyosera km 2550 code earer c0410 help me
Kyosera km2550 after sum copy makes service code c0410 off machine then rady after sum copy make then code co410
5 Suggested Answers
n25an
  • 622 Answers
SOURCE: I am trying to set up newtwork scanning on our
cool... ok here is what you do goto usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
Posted on Dec 22, 2009
aimrans78
  • 52 Answers
SOURCE: I want add a KM-2550 as a printer on an XP
u can come to know from the server
where its physically installed
goto printers and faxes
then oen printer properties
and there is a tab named shared
see the name there
and write it
and then
u can add to the other macine
and can install
Posted on Jun 18, 2010
shawn38
  • 200 Answers
SOURCE: kyocera km 2550, copies are
If your prints or status page prints normally and the light/faint area is only when making a copy then the mirrors in the optics need to be cleaned. They can get dusty or build up a film on them. You must turn off and unplug the copier then remove the large glass that you place your original on. There are two screws to the left of the large glass if you remove them the piece of plastic that holds the glass in place on the left can be removed. Left the glass off. If you are careful you can grab the center of the mirror base that houses the lamp that comes on when making a copy and slide it slowly to the right. This will allow you enough space to clean the mirrors. Use a clean lint free cloth with a mild glass cleaner (with no amonia). Put everything back to were it was and plug in and turn on the machine and you should be all set.
Posted on Jan 19, 2011
  • 523 Answers
SOURCE: my kyocera km-2550 multifunctional copier has
This is fuser unit error code, you can try to reset it might work, but if the erorr code came back then you need to change the fuser unit.
In order to reset this code: follow those steps
on the panel press 1087 1087
The screen will change to service mode
on the panel again press 163
now look at the screen and you will see Excute.
Select Excute and press the Start key.
The Machine will rebot or it will asks you to turn it off and on.
After the machine load again, it should be good, if the Error came back!! Then change the Fuser Unit.
Posted on Nov 12, 2011
Error c3200 on km2550
Clean the slit glass or open the glass and clean the mirrors from the dust.
Mar 25, 2017 | Kyocera Mita KM-2550 All-In-One Laser...
Kyosera km 2050 error code co180 display
Machine number mismatch
Machine number of main and
engine does not match.problem is Data damage of
EEPROM.
Apr 09, 2014 | Kyocera Mita KM-2050 Printer
Kyocera KM2550 printer prints test page but cannot print word documents and pdfs
Try loading paper in the bypass on the left hand side of the machine.It may be that you are trying to print a document that is a different size to the paper that you have loaded in the copier.
Jan 13, 2014 | Kyocera Mita KM-2550 All-In-One Laser...
BLANK COPIES FROM KM 2550
first chek dev unit toner? pls insert toner 1087+ 1087+ 130 set dev enter ok then 10 mnt wait and check drum and dp closing time corect sitting or chage edge of dp unit you cleang time smothing wrong?? comng blnk copy
Aug 03, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
My kyocera km-2550 multifunctional copier has started showing a error message "call for service c6000" and a phone number in asterisks. kindly advice on what to do or if there any online help.
Oct 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
I have Kyocera km-2050 it coming error for call for services error code -C6400
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
I want add a KM-2550 as a printer on an XP machine. I know what the host name of the KM-2550 is. The KM-2550 is definitely on the network because I pinged it from the XP. How do I find the name of the...
see the name there
and write it
and then
and can install
Jun 18, 2010 | Kyocera Mita KM-2550 All-In-One Laser...
How can i set up KM2550 to scan
install the paper port software from the printer driver cd and use it to scan
Dec 16, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
Minolta EP2030 exposure lamp timing wrong
"Exposure lamp timing wrong" simply means that the lamp is coming on at a time when it should not be coming on. It is not a problem with the lamp itself. It is most likely a power supply problem. There is probably no simple fix.
Just because Konica Minolta no longer will sell you an agreement does not mean that you cannot get the copier serviced. There are plenty of independent repair agencies that would love to service your copier, unless you are in a really remote location.
The EP2030 was one of the last Minolta analog copiers, and parts are still readily available.
Nov 13, 2008 | Minolta EP1030/1030F CS/PRO Copier
Kyocera Mita KM-2550 All-In-One Laser Printer Logo
181 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
