Question about Freezers
Bottom freezer door dripping water on kitchen floor
I have a Sub Zero Model 550, refrigeration on top, freezer door on bottom. Unit is 13 years old. Recently found water dripping on kitchen floor from freezer door. Freezer door gasket was replaced. Still having the same problem. Water is puddling on bottom of freezer compartment. It is freezing then thawing and dripping from bottom of door onto floor. What could be causing this? Any help would be appreciated.
    President:
  • Freezers Master
  • 2,651 Answers
You can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Posted on Jan 14, 2009
SOURCE:
Whirlpool refrigerator with top freezer
If there is an ice maker in the freezer, look to see if the water is coming from there. If it is then replace the solenoid valve where the water comes into the back of the refrigerator.
Mar 05, 2014 | Whirlpool Freezers
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Sub-Zero model 550 does not cool properly
make sure the coils are clean first both coils, then check the r22 freon
Jul 21, 2009 | Freezers
10+ years old sub zero 550. ice cubes are green
I would not recomend using those ice cubes. Sounds like theres lots of mold or worse growing in your freezer. I would get rid of it. ;(
Jul 09, 2009 | Freezers
Freezers Logo
661 people viewed this question
Top Freezers Experts
Dennis Boxerman
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
