Question about JVC Lamp/bulb For Hd-58s998, W/housing, 150days Warranty
How to fix blinking lamp light jvc on HD-58S998
Blinking lamp light
BMW Rider
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
SOURCE: Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Posted on May 11, 2008
SOURCE: JVC HD-527575 problem
We just had the same problem. The Projector lamp is burned out. You can get the lamp at Electrified.com. Their phone # is 800-678-8585
Posted on Oct 22, 2008
SOURCE: JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Posted on Jan 25, 2009
fieldy14
  • 456 Answers
SOURCE: rapid blinking light (lamp) on a JVC model HD
It normally means the lamp is in need of being replaced, and its all depending on the use of the TV as well as how long the lamp life is. You should be able to access the lamp via a small section near the rear or the back of the TV unit, if the lamp is blown or faulty it will look the same as a blown light globe.
To obtain a new lamp contact the brands authorised repair agent as they will be able to get trade prices and in turn, give you the best price,
Also make sure that whoever replaces the lamp resets the lamp use time as the TV will still not start if you don't reset the lamp use time as it will still think it has a faulty lamp. I hope this helps, good luck.
Posted on Dec 05, 2009
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
The red and blue light on the front keep flashing when we try and turn the TV on...it was working earlier today.
If Power and Lamp lights blinking 'alternately' it shows problem of temperature arise abnormal and reason could be blocked fan or air flow in tv is insufficient to keep it cool.
If Power and Lamp lights blinking simultaneously then it shows problem with lamp installation, need to inspect lamp cover is fixed in its position securely.
Let me know both lights are blinking at same time on your tv?
Thanks.
Aug 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Cant get our HDMI to work on our JVC HD 58S998.
First, contrary to popular opinion, HDMI cables connect to a tv are not the best way to connect the two. The HDMI technology has flaws that often shows up as sound problems.
If your TV has the capability for component connections, use them. It will take 5 cables, 3 for video and 2 for audio. You will get superior sound and video. The 5 cables terminate in RCA type connectors and are much cheaper than an HDMI cable.
I hope this helps and solves your problem. :-)
Jan 03, 2010 | JVC Televison & Video
Rapid blinking light (lamp) on a JVC model HD
Dec 05, 2009 | JVC HD-52Z575 52" Rear Projection...
JVC 62" tv cut off and won't turn back on. red light blinking?
easy fix. here is your lamp part number TS-CL110UAA and your lamp door maybe hidden behind your front panel. check your lamp before you order one.. and shop around for the best price on your lamp. if you want to rebuild your lamp its cheaper and only a little more difficulty.. if you run into problems use our fixya chat..
Mar 16, 2009 | JVC HD-61Z786 61" Rear Projection HDTV
How do i reset my jvc tv
Either a bad lamp or bad reciver board.If audio amp ic on reciver board shorts ,it will kill part of supply and lamp ballast will not turn on and fire lamp.
Dec 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Oct 10, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC Lamp/bulb For Hd-58s998, W/housing, 150days Warranty Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
