Question about Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television
Improper format I get the message "improper format" after loading a DVD. Help.
  • sommer Feb 18, 2008
    I have the same problem everthing else workes fine with the unit but I will not play DVD, it tells me inproper format with DVD's it is suppose to work.
    I went through all the troubleshooter suggestion in the menu.
    Problem Solver:
  • 15 Answers
YOUR OPTIC LENS NEED TO CLEAN OR IMPROPER REGION OF CD
Posted on Aug 27, 2007
I have a yamaha dvd-c750. I have just created a slideshow using iphoto on a Mac, burnt to a TDK DVD +R. Inserted into the DVD drive. Machine tries to load it. Gives a message "unknown disc"? ...
DVD players can be picky with the type of file format that they use. According to an amazon.com review of this player, it does read DVD+RW/+Rs & DVD-RW/Rs so the problem probably resides in your file format.
The problem is probably the fact that the DVD Player does not recognize the file format of your Mac slide show. The computer recognizes this format, as it plays the slide show. The DVD player recognizes JPG file formats, which is the standard format of a picture.
If a DVD is made with JPG Files, not your slide show files, it will display thumbnails of each picture, allowing the choice of what picture to view.
If the slide show is a must, try to save it to a video file format, such as a *.mpg or *.avi which are common video file formats. These files would be movies of the slide show that you have made.
Mar 16, 2011 | Audio Players & Recorders
Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
6 seconds into recording the following message appears: write error - to recover disc, presss OK. having pressed 'OK' the screen then shows 'Disc Loading' message - this takes time and uses up battery...
It turned out to be a simple case of a defective disc, which, for some reason failed to work satisfactorily. I replaced it with a fresh disc (JVC 30 min DVD-RW) from he same batch and it formatted ok and worked well too. I checked that it had recorded and I was pleased to say that it had. So let's hope that that was the cause of my problem, because the camcorder is now just out of warranty.
Many thanks for your halp in this matter.
Regards.
Jim Stringer
Oct 13, 2009 | Samsung VP-DC161 DVD Camcorder
Disc error "playback feature may not be available on this disc"
Hello arnita2211,
This error message is due to an improper format, that your dvd player can't handle. To correct this you need to use a program such as nero and in nero is a program called nero vision, that will recode the movie file into a dvd playable format.
You can download a trial of nero here
http://www.nero.com/enu/downloads-nero9-trial.php
You will have to purchase a license when the trial ends. Sorry we cannot give you a serial key for this as it is Illegal.
Thank you for trying Fixya!
Apr 08, 2009 | Philips Magnavox DVD/VCR Dual Player
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Disc Error
Try to clean the read laser and the laser pickup, by using a DVD cleaning disk. If this does not work you may have a misaligned laser or pickup.
That may sound like a canned response and it is, however it is a good start. I would also check the format of the video on the DVD-RW, and make sure the DVD player is set to display that format.  Also might I suggest that you try the documented Disk loading instructions. I know that sounds stupid, but I was working on a customers DVD player one day and I downloaded the manual, and I was shocked to find out that I was not following the recommended loading procedure, once I did that all of the disks worked (stupid? yes, but that's how things are now).
As I said try to clean the pick-up and laser, check the format of the DVDs, and then follow the recommended loading instructions.
I hope this helps
Thank you,
Shuttle83
Apr 23, 2008 | Sansui VRDVD4005 DVD Player/VCR
DVD will not load/format new disk
I have got exactly the same problem. Thought I had found some discs that worked as the first one formatted, since then all have come up with that crappy error protection message. Samsung really should sort this out.
Mar 25, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Not an Audio CD/Format Unsupported
Clean the CD and try again. Also, if DVD displays "not supported", call Bose and ask to recieve an update disc. These updates are released every 6 months. Document your remote control settings before loading the update as they may be erased by the update and will require re-entering settings after the update.
Dec 24, 2007 | Bose Lifestyle 38 System
Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television Logo
96 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
