I need a manual for a candy 1600 gof 662 washing machine
4 Suggested Answers
  • 6277 Answers
SOURCE: i have lost my manual to my Candy GO F 662 washing
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Oct 15, 2011
  • 1416 Answers
SOURCE: candy washing machine grand go f 662 stops mid
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your selfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reset the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Posted on Nov 08, 2011
esterhuiz997
  • 80 Answers
SOURCE: Candy gof 662 has smoke coming from it and I found a screw and large bolt under the machine
just replase the wire of the motor and the swicth
Posted on Oct 14, 2012
I have a Candy GOF 662 and the dial seems to be out by two Programs
There is a plastic lug broken off inside the dial. If you pull the front bit off you will see that the front is held in place by it. You probably need a new dial, but, in the meantime, mark the front bit with a permanent marker with numbers corresponding to each function you need. It may not be the same number of clicks, but it will be the same distance around the dial.
Apr 26, 2014 | Candy Washing Machines
Do you have a user manual for gof 462 2/8
Dear Sir:
go to www. fitness.manualsonline. com or www.retrevo.com
or www. manualsfactory.com
God bless you.
May 13, 2012 | Candy Washing Machines
I have lost my manual to my Candy GO F 662 washing machine and need to know the spin cycle symbol
Manual
John C.
Oct 15, 2011 | Washing Machines
Hello, I was given a CANDY Smart washing machine CTG 856 but there is no instruction manual. I searched for the manual online but there was none available. Do you know where else can I find one? the main...
hi
the manual for you washing machine is not yet available online but you can request for it to be sent to your mailing address and you will get it shortly.
the link is
http://www.candy.it/libretti/libretto.cfm?lang=2&country=7&brand=candy
Aug 27, 2011 | Candy Washing Machines
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
