Question about Behringer Control DJ Mixer BCD3000
What are the output voltages of psu board bcd3000?
2 Suggested Answers
  • 269 Answers
SOURCE: my UB2442HX mixing console lost
Might be a Capacitor power supply problem. I would check the Power supply Caps.
Posted on Jan 04, 2011
I have a Peavey Bandit 50 watt guitar amplifier that has no output with the exception of what seems to be a 60 cycle hum.
The schematic I grabbed from blueguitar.org shows several fuses in the power supplies. Did you check those, especially the one for the high voltage supply for the output tubes - fuse F1 on 'main board' ?
Feb 06, 2018 | Peavey Music
What is the input and output amperage of 15G fender guitar amp.trandformer?
Transformers change the voltage and not the amperage. The input would be 110-120 volts. The output voltage would be stamped on the transformer or the circuit board where the transformer is mounted. It either steps it up or down. Make sure to disconnect it before investigating. Good luck!
Mar 13, 2016 | Fender Music
I have a Kurzweil pc88. The unit function but the power board 7805 voltage regulator overheats and eventually shuts down after 7-8 minutes. All else appears functional. Any suggestions?
Try changing out regulator . Check voltage output and resistors are a good culprit in these cases. Are you sure the rectifiers are doing there job ?
Feb 23, 2015 | Music
How do I install the driver for my bcd3000 .I get stuck on relaunch cotrolpanel
Check the following website to see how your problem compares with others that have a similar problem.
BCD3000 Traktor not working on new laptop
Feb 09, 2015 | Behringer Bcd3000 B-control Dj Mixer...
Why does fuse blow when unit is powered up
I rather suspect IC1 TDA7293 is the cause of your problem. If this is the case you will need to check the speaker/s
Nov 12, 2014 | Marshall Amplification Marshall MG250DFX...
Bcd3000 repair manual
Basically you've got no chance. Behringer are very protective and use proprietary parts so when out of warranty most of their items are throw away.
We always insist with our main suppliers that we get a repair and service manual at the time of purchase or we do not buy. This has stopped us buying on several occasions, We do still buy some behringer kit but only because of the three year warranty, we then sell before the three years is up. Most major manufacturers have no problem supplying the manuals however, and this has saved us a lot of money as we do some repairs in house. We do spend many 000s a year so maybe have a little more clout than some.
Nov 18, 2013 | Behringer Control DJ Mixer BCD3000
I can not install my bcd2000 to windows 7. the hardware and softwere
Four things to check:
Sometimes you must leave the device disconnected while installing.
You must turn OFF ALL anti-virus, spyware, anti-adware, popup blockers during install.
Sometimes you have to do the install in SAFE MODE.
Make sure the driver you have is Win 7 compatible.
Aug 10, 2011 | Behringer Control DJ Mixer BCD3000
I get a distorted sound from my speakers throug a Phonic Helix Board. It is connected on a PC through Fire Wire. The distortion is also there while using microphones or other inputs (CD-players etc.). It...
Hallo landgenoot ;)
It seems it is a power supply problem; distorted sound, no meters, solo buttons not working, headphones low level and distorted. One of the power supply voltages might be too low or even missing. The Helix series mixers use mainly 4 supply voltages: + 15 V and - 15 V for the analog part (audio), + 5 V for the DSP and logic and +48 V only for the phantom power. If for example the + or - 15 V is too low, clipping of the positive or negative parts of the waveform (dependng on which voltage is too low) will occur. If possible, first measure the voltages coming out of the power supply. You could use a metal part of a jack as ground reference.
For the FireWire board an extra voltage supplied by the switched PSU is used. It is specified as +12,2 V, but I measured 14 V. This voltage is lowered to + 5 V by a resistor on the FW board and a 7805 regulator. (Not very efficient!) But as far as I can see, the FW voltage is not the problem here. I have some service documentation of the Helix series mixers (12, 17 and 24, so if you need more you can conatct me: frankdevries [at] versatel.nl.
Groeten, Frank.
Mar 18, 2011 | Phonic Helix18fw 18 Channel Mixer with...
Behringer Control DJ Mixer BCD3000 Logo
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
