Question about Movado Esperanza 0605285 Wrist Watch
How to remove links for a movado esperanza - Movado Esperanza 0605285 Wrist Watch
4 Suggested Answers
escapement
  • 2334 Answers
SOURCE: How do I remove links on a Movado elliptica?
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jan 09, 2010
mcdevito75
  • 1970 Answers
SOURCE: remove links on Movado Rondiro #605499 to make the
mcdevito75 here, By the time you recieve the special tool needed to reove the links you can have a small watch repair shop in your area do the job.
Posted on Jul 01, 2010
mcdevito75
  • 1970 Answers
SOURCE: How do I remove a steel link from a Movado
mcdevito75 here, Special tools neede to remove links, Best Bet look for a small watch repair shop in your area, and hold onto those links once removed as you may need them again in the future.
Posted on Oct 16, 2010
How do I remove a steel link from a Movado wristband 800 series?
Oct 16, 2010 | Movado 800 Performance watch
What if my small slide over the battery has come off completely? how do i put it back?
It should slide into/under a slot from the side, and be held in place by tension (not familiar with the exact model, so bear with me...). Some covers are held in place with a screw; you'll know this is the case if one end has a hole in it. Eyeglass screw kits are a good source for tiny screws. Hope this helps!
Sep 29, 2010 | Movado Museum Esperanza 604122 Wrist Watch
Remove links on Movado Rondiro #605499 to make the bracelet smaller
Jul 01, 2010 | Movado Rondiro 605964 Wrist Watch for...
Movado Juro watchband. How to shorten
mcdevito75 here, Best Bet, look for a small watch repair shop imn your area to svae on cost, special tool available on ebay is needed since it's a Movado let the shop remove links to re size.
Jun 23, 2010 | Movado Juro 0605024 Wrist Watch
The band broke and i need a replacement
I just searched ebay and there's a bunch of replacement bands available for the Movado watches... some great choices....
ebay.com
Jun 25, 2009 | Movado Esperanza 0605285 Wrist Watch
I NEED TO ADD 2 LINKS TO MOVADO WATCHBAND .THE CASEBACK # ON WATCH IS 88.E2.887.2.the #on band is v144.g.2
An authorized Movado Retailer can order the links for you. you can locate a local retailer on www.movado.com
http://www.movado.com/FindARetailer.aspx?
Jan 21, 2009 | Watches
Changed battery in Movado. Is there a way to reset?
No, there isn't any buttons you are missing.
My first advie is to test battery for full power. If it is, then clean all contacts in battery hatch.
If it still do not work, the gear train can be jammed or the integrated circuit faulty and repairs can be undertaken by skilled watchmaker only.
Dec 03, 2008 | Movado Museum Esperanza 604122 Wrist Watch
Movado Cronograph - Can't remove pin!
you need to push it thru wit a ling "needle type" toolin order to get it out. it has to be strong enough so that it doesn't bend also because it's quite stuck in there pretty good. thats part of the quality you get from a movado.
Jan 26, 2008 | Movado Kardelo 0605479 Wrist Watch
Movado Esperanza 0605285 Wrist Watch Logo
261 people viewed this question
Top Movado Watches Experts
Jimmy Accardi
Are you a Movado Watch Expert? Answer questions, earn points and help others
