Question about Hotpoint Washing Machines
Machine locked and no lights on hotpoint Aquarius wdal8640
Machine has gone off but door won't open
murdozzz2
  • 75 Answers
SOURCE: Hotpoint Aquarius Extra washine machine. Won't start..
hi there the pcb behind the control panel is blown this is due to the carbons running low
Posted on Dec 10, 2007
SOURCE: hotpoint aquarius washing machine
where is the filter for hotpoint aquarius wma54 washing machine
Posted on Sep 12, 2008
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
  • 5 Answers
SOURCE: hotpoint aquarius wf320 1200 spin
its blocked...try the waste pipe
Posted on Nov 14, 2009
SOURCE: my hotpoint aquarius WML560 DOOR WONT OPEN EVEN
take the bottom front panel off and pull down on the green plastic cable on the left side
Posted on Jan 30, 2010
Hotpoint 6kg washing machine Aquarius wash light indicated door lock indicator flashing machine won't fill any ideas thanks Brendan checked filter ok
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Jun 04, 2015 | Hotpoint Washing Machines
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
My hot point aquarius wmf940 washing machine door won't lock
If this model has brushes check them first.
check wiring to door lock
new door lock
new board/motor.
This is the order i would go at trying to solve the problem
May 23, 2012 | Hotpoint Washing Machines
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius wf320 door won't open.
what you need to do is say 'abracadabra' 3 times , then swear allegience to the queen always remembering Glasgow Rangers are the best ..hee hee
May 04, 2009 | Hotpoint Aquarius WF000 Front Load Washer
On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius washing machine
May 31, 2008 | Washing Machines
Washing Machines Logo
135 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
