Question about Health & Beauty
I have a wheeltec rio 3 mobility scooter i bought new batteries for it charged it up, went to try it out and it would not move. the power eye is on but keeps flashing and it makes a noise when i turn
It is 7yrs old and has been used once
gewiz
  • 1263 Answers
SOURCE: We have charged the battery and when we turn on
So the Battery charger is showing a green light (Fully Charged ?) Can you tell me the MAke and Model of the Scooter ?
Posted on Jun 13, 2009
  • 39 Answers
SOURCE: Have Zoom 220 HMV 3 wheel scooter. Charged battery
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Posted on Jun 23, 2009
  • 175 Answers
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Posted on Jul 12, 2009
  • 92 Answers
SOURCE: I have purchased new batteries for my mobility
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
Posted on Apr 06, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
Tip
Does this contactor switch, means that the broiler element stays on when you...
If you have ever experienced your electric oven not shutting off, then you know what it is like to have the oven overheat. It can be a very scary experience. If this happens to you the only thing that will turn it off is unplugging it from the wall outlet or turning off the circuit breaker. Either one of these actions will totally turn off the power to the oven. This will make sure that the oven will no longer heat.
Now, the question is. What happened inside your oven to cause this problem? The problem is with a device called a contactor. This is just a very heavy duty switch that turns the current on and off to the heating element in your oven. Every time this switch opens and closes a small spark or arc happens. Every time this spark happens a small piece of the surface area is melted. After this happens thousands of times the surface of the contactor becomes very rough and the two surfaces do not connect very well. When this happens the surface becomes hot enough to melt a large area of the surface. This melted surface then “welds” together. Now the contacts cannot pull back apart and your oven is on continuously.
The only fix for this problem is to replace the contactor. This is not a hard task and can be done by most handy persons. Just make sure that you have the correct replacement part and that all the power is removed from the stove/range/oven before you attempt to replace it.
If this problem does happen to your oven and you did not realize it for a long time, you should also expect to have other problems after you fix this problem. The excessive heat will cause other problems such as burnt wires, terminals, burnt fuses, and a number of other problems that would be heat related.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Apr 25, 2010 | Ovens
Only stripes on screen
What is the brand name and model number?
Jun 19, 2013 | Televison & Video
My Toshiba Laptop Satellite Pro computer is about 7yrs old.
Yes., stop using it and have to backed up to a new drive as quickly as possible. This is what Toshiba drives do right before they die.
Jul 23, 2010 | Toshiba Computers & Internet
Is this TV HD compliant? Dan K
NO, it sure isnt! anything over 7yrs old is not HD And Any Set that does Not Have HD printed on it is NOT HD!
Dec 21, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Poor cleaning leaving deposits,dishes feel dirty
The problem for the spots is hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Aug 04, 2009 | Thermador DW44Z Built-in Dishwasher
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Health & Beauty Logo
135 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
