Question about Canon EOS 400D / Rebel XTi Digital Camera
Auto focus suddenly stopped working
I have a Canon EOS Rebel xti and switched from AF to MF on the lens barrel. When I switched back to the AF position, it wouldn't work.
  • chris5515abc Jan 15, 2009
    auto focus stopped working all manual setting work
This may not be the same as your issue, but our AF stopped working as well. I tried all the recommended fixes - removing the card and battery, recharging the latter, removing the lens and cleaning the contacts, etc. None of those things worked. However, I then switched to MF, requiring me to turn the barrel, and I realized it was stuck and just needed a little force to get unstuck. Might have been the humidity. Anyway, our problem was solved - AF was back to normal after that.
Posted on Aug 24, 2009
  • yvettech Jun 13, 2011
    On holiday and half way through AF has stopped working altogether and I have been struggling with MF. Thank you for your tip my camera/AF is now working perfectly after giving the lense a harder tug.
  • 38 Answers
Turn the camera off and remove the battery. Wait a few seconds then plug the battery back in. This should cause the camera to reset itself and hopefully get the autofocus working again.
Hope this works for you
Posted on Feb 09, 2009
My auto focus not working I have cleaned connectors
Sorry I only have a such manual, but on the drawing it says Focusinstellingsknop (pag. 30).
That switch, on the lens, should on AF and not on MF. Did you check that one?
All EOS lenses do have such a switch.
Aug 17, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
Canon auto focus lens will not operate
If lens has AF/MF switch, make sure it's set to AF. Check/clean connectors between camera and lens. Try with good light source.
Dec 04, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon EOS Rebel XT 350d will not autofocus.
Sound like a broken ribbon cable in the lens. Needs to be replaced but get a quote as it may be cheaper to replace the lens with a secondhand one.
Mar 14, 2017 | Canon Rebel XT / EOS 350D Digital Camera
EOS Rebel G 35mm SLR Camera: auto focus has stopped working...
It could be either of two things.
1. AF motor in lens died. Try a different lens and see if it works.
2. AF module in camera dead. This requires repair shop to install a new module.
Before you do either of the above, put in new batteries and check the setting of the AF/ MF switch on the lens itself.
May 03, 2010 | Photography
My canon rebel XSi will not auto focus
Actually what I found to solve the problem was to first set the lens in "MF" and practice taking a picture manually to see if that would work. When I did this, I discovered that the fine tuning portion of the lens was somehow stuck mechanically. I heard a loud click as I turned it. That was all it took to fix the focusing mechanism on the lens. Then I set to "AF" and Voila, the camera worked just fine.
Apr 04, 2010 | Canon EOS Rebel XSi Digital Camera
See-through lens is blurry and does not reflect the change in focus when I adjust the wide angle lens on my digital rebel xti. What's the problem and how can I fix it?
Check the AF/MF switch over the lens left side. Should be on AF to let the camera focus by itself. If not, you have to manually focus using the focusing ring.
If the camera is in AF and still no focusing, considere to carry your camera for service.
Aug 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Iso to auto
On the back of the camera to the Right of the LCD there is a up-down-left-right-center switch. push the up one. (Labeled ISO) then use the same selector switch to select the ISO you want and then press the shutter half way down. If you are shooting in a low light situation, the auto focus sometimes will not work. Change the switch on the lens from AF to MF and focus manually.
Sep 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
355 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
