Question about KitchenAid Food Mixers
Oven wouldn't turn on, screen said F2E1
After it cooled I pressed Cancel and everything worked again. My worry now is should I still have it looked at or should I Keep the cake pan OFF the bottom of the oven from now on? Will that be enough?
  • KitchenAid Master
  • 5,124 Answers
If you have a KitchenAid range, the F2 E1 code indicates a keypad problem. If it recurs and continues to give the error after you press Cancel, then you will address the issue. The cake pan position has very little to do with the error.
The fix could be as simple as finding a damaged conductor in the wiring harness and using a conductive silver pen (or use the rear window defrost repair kit liquid applied with a needle and not a wide brush) to repair the break. On some ranges you might need to replace the keypad. Other models have the keypad integrated into the ERC (clock and entire control panel).
I hope this helps.
Posted on Dec 03, 2012
Mixer won't turn on after adjusting beater height
The kitchenaid warranty is exactly 365 days from date of registration "No Questions Asked" on day 366 you have no warranty and you gotta pay.
Now the good news; first check the wall socket, I know it works but check it anyway. then check your plug, did you step on it while you were working on the machine? The plug often falls to the floor during work and can get underfoot, you may have broken the plug it'self. next you will need a parts list for your model from Kitchenaid's website.
http://www.kitchenaid.com/customer-service/manuals/
My first suggestion is to try a minor adjustment of the speed control switch, they often get out of sync when you do something to the machine. You can find several videos of this on the youtube site. "Adjusting the speed control switch on kitchenaid mixer"
If the two or one of the top 2 screws on the speed control switch move it can shut the machine down just like an on/off switch. Did you remove the back cover during your adjustments? Did you remove and replace the carbon brushes on the side of the machine while working on the machine? If you did you might have put them back in incorrectly, if you did they will also act a a shutoff switch. If you did not take them out then DON"T as there are four ways to put the brushes back in and only one way is correct and there are two brushes to deal with. Has work ever been performed on the mixer before? Because if all you did was to adjjust the beater height screw then nothing should have effected the normal operation of the mixer. So if there is anything that you did but did not include in your description of work you performed then please let us know. We strive to give accurate solutions but... as I am a KA tech I do not have any other solutions with out the machine in front of me. Just so you know you can fix this yourself.
May 26, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
What to do with my kithenaid mixer - we moved and oil from the engine was leaking?
If you have already fixed the problem then great and I'm sorry that i didn't see it sooner. If you have not then do this first. BTW if you are under warranty this WILL NOT VOID the warranty.
Solution 1; There is a silver ring around the front of the mixer that you attach your beater or whip to. Take a nonmetalic hammer and a screw driver, place the screwdriver on the top edge of the ring and tap LIGHTLY on the screwdriver. The ring will fall off after a couple taps. DO NOT hit it hard, you can scratch the finish all the way down to the raw Zinc frame and you can knock the ring out of round. The ring is only held on by pressure so if you knock the ring out of round it will not stay on anymore. Onward and upward...turn the mixer upside down (On a Towel or you will scratch the finish) and you will see five screws that are now exposed tighten them down again. They won't turn much so don't worry it only requires about a 16th. of a turn. What you have just done is to tighten up the two parts of the mixer and apply pressure to the gasket / seal that hold the gear head grease in. While you have the mixer in this position (you have probably figured it out by now that someone else is holding the mixer upright while your working on it) you will find 4 more screws that attach to the mixer toward the rear. Give them a little tighten turn also. Now take the silver ring and place it back where you took it off from and tap it back into place. This ring is held in place by pressure only. If you find that the ring is not going on not to worry. You can give it a good whack as long as you hit straight down. If you knock it sideways you can knock the ring out of round and then it will never stay up again. So be careful with the hammer. If you look closely at the inside of the ring you will see what may be called "Stretch Marks" from where the ring was originally move it past those marks and tap it on. going back to the original stretch marks does not always work and the ring falls of so choose a new position for putting the ring back on.
Solution 2 THIS WILL VOID YOUR WARRANTY. If you proceed with this step and your mixer is under warranty you will void the remaining time on your warranty and you will be doing a basic tear down of your mixer. So first you need to order two parts, a gasket and some food safe grease. do a search for kitchenaid grease and kitchenaid gasket and you will find both at several sites including Amazon, so check pricing and shipping as both vary widely between sites. The next thing to do is go to kitchenaid.com and download a parts list for your mixer by clicking on the support tab and then click on download manuals and user guides. This will give you a working diagram of your mixer so that you can follow along with your work. The next thing to do is go out on the internet and search for a video that is out there that will walk you through it step by step. Change grease in kitchenaid mixer will take you there. To do a write up step by step would take a long time and a lot of space. It is basically eleven separate steps of dissassembly to get to the gear case grease then you have to clean out the old and re-pack with new grease and put it all back together. during the process you can knock your mixer out of "Speed" and then you have to re- tune the mixer speed. again, not hard but another step to do and there is a video on the internet for that too. You can check with Kitchenaid Customer Service and they will put you on to the nearest Factory authorized sevice center, If you are close you can drop it off if it is far away you will have to ship. the mixer weighs 25-30 pounds and will cost $25-30 dollars to ship. they will get return shipping. the cost of the re-pack also varies by state and location. In Orlando Florida it costs $110.00 to have it done plus shipping. In Miami if you haggle you can get it for $90.00 and if you don't have to ship at all it will be less. the job is not hard but it will require your time (2 Hours for the novice) and lots of patience and a work area that you don't mind getting dirty. DO NOT do this on your wife's kitchen table she WILL shoot you when the grease gets all over the place. good luck.
Aug 05, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
Planetary Plummets!
go buy a bottle of lock tight also called thread locker (red bottle) and apply some then press it in place while still wet , let dry and it should stay on
Mar 20, 2017 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid Professional HP mixer, motor stopped while making dough. I let everything cool down and with no attachments it will not turn on. As soon as you turn it on the motor gets hot but no noise or...
Open the Transmission Housing and remove the two screws holding
the Motor. Lift it off the gears and test run it by itself. The motor
should run normally at different speeds. If it does, then you can move on
to the gears. Manually turn the Worm Gear and make sure nothing got jammed.
The Bevel Gear should turn smoothly.
Jul 18, 2011 | KitchenAid KP2671 Professional 6 Series...
I was grinding some meat and my mixer got very hot. I let it cool down and now it only operates at one speed.
I am not sure what has happened to your mixer but, select
different speeds from Stir to 10. If it runs OK, then there is
nothing to worry about, otherwise do the following to re-adjust the mixer's speeds:
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have a KitchenAid Professional 600 Series 6-Quart Stand Mixer, model KP26M1XBS, which no longer works. I was mixing pretzel dough and the mixer stopped turning. I initially just thought it overheated...
Don't worry about the Worm Gear for now. You have to make sure that the Motor
is fully functional by itself: Remove the Transmission Housing Cover (4 screws) and
the two screws holding the Motor down. Lift the Motor off the Worm Gear and set it
on the side (be careful of AC voltages from the Motor and Control Assembly).
Select Stir setting and observe the motor shaft. Is the Motor running? If it is,
Select other speeds to see how the motor performs.
With the motor now fully functional, you can now check the Worm Gear Follower
for worn out/broken teeth. Remember the motor drives the Worm Gear, it then in
turn drives the Worm Gear Follower (you may have to remove the grease to see it)
The Bevel Gear sits right on top of the Follower and drives the Attachment Gear.
Jul 06, 2011 | KitchenAid Food Mixers
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer will not turn on.
Please what model of Kenwood you have ?
if is 901 press the green boton. inside when you up the head.
if with that not working. is necessary check the motor and change some components .
regards
Kenwood Chef Restore
Dec 28, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Mixer whine
Unfortunately, the Kenmore mixer sounds louder than freight train due to a poor planetary gear design. I had to take mine back so that the neighbors wouldn't **** me. I hooked up two identical models at the store to get the same, painfully loud, experience. I think I prefer the sound of a bandsaw to the grating noise it produced.
Jan 01, 2006 | Kenmore KSM100 Stand Mixer
Food Mixers Logo
209 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
