My name
SOURCE: How do I convert from decimal to binary?
change your mode to binary , then enter your decimal no in dec link and then press bin link you can get the binary equivalent
SOURCE: Convert to/from Decimal/Binary
Press MODE 4 to enter the BASE-N mode. If the display doesn't say Dec, press SHIFT DEC (the x^2 key) to set base 10. Enter the number to convert. Press SHIFT BIN (the log key) to switch to base 2.
Each time you switch the base the current value is redisplayed in that new base.
SOURCE: Convert between decimal and binary and back again
Sorry but this calculator cannot do calculations in other numerations just decimal. To make sure examine the calculator looking for markings like BIN OCT HEX. If you do not find any (and you will not) then you can be sure that it does not perform base conversions.
SOURCE: How do you convert decimal
Press MODE 4 to enter the BASE-N mode. Type in the decimal number, then press BIN to convert to binary. Press DEC to switch back to decimal for the next conversion.
You're limited to numbers in the range [-32768...32767] in binary. You can extend the range if you convert to octal or hexadecimal and then mentally convert each digit to three or four bits.
SOURCE: I have a TI-89 and
Enter the binary number with a 0B prefix.
Testimonial: "Thank you for the help! It worked great. Just use the prefix 0b and it goes!"
