Dimplex mcn20 just stopped working - wont switch on - we changed the fuse but its made no difference do you think its the switch?
3 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
Posted on May 27, 2010
  • 4736 Answers
SOURCE: what type of bulb is required for the mcn20
Steve, a 60 watt, small base, chandelier bulb is what is required. There are usually 3 to 4 of them in most electric fireplaces.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 17, 2011
Dimplex cheriton fire model CHT20LE wont turn on
Check the fuse isn't blown in the plug. If it is not, then you would unfortunately need to open up the fire and check the internal wiring and connections, check the switches with a multimeter to make sure they are working. There really isn't much inside these units to go wrong! So any fault should be rather easy to find
Aug 02, 2013 | Dimplex Heating & Cooling
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
Went to switch on fire switch blew up i have changed fuse in plug thats all ok so i think the triple switch is blown .
To purchase a new 3-way rocker switch, contact Dimplex Tech Service 1-888-346-7539.
Hope this helps and thanks for choosing FixYa.
Sep 22, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
What type of bulb is required for the mcn20 dimplex fire thank you
Jun 17, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Bulb blew in my dimplex michigan fire, model MCN20. I now can't get the bulbs to switch off with either the remote control or the on/off switch.
Stewart, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON and set the function controls manually (not with the remote) one at a time. If everything works as it should, the fire reset itself during the 12 - 15 minute timeout. If it didn't or that problem continues to reoccur, contact Dimplex North America, Technical Service at 888-346-7539.
Hope this helped you solve the problem.
Apr 27, 2011 | Heating & Cooling
I have a Dimplex model D55804C SN 19005D4F579. the lower bulbs behind the flames do not light up. I changed the bulbs thinking that was the problem, but still no light. Can you tell me what I need to...
Maryanne, the first thing to try is turning the Master ON/OFF switch to OFF. Unplug the unit and allow it to remain unplugged for 10 - 12 minutes. Generally, that's enough time for the unit to reset itself. Plug the unit back in and turn on the Mater On/OFF switch and then proceed as you normally do.
If that solves the problem great! If it becomes a recurring problem, turn the fireplace off, unplug it and call Dimplex USA Technical Service 888-346-7539.
Hope this helps to solve your problem. Please let me know.
Mar 15, 2011 | Dimplex Heating & Cooling
My Dimplex coal effect black stove won't work. The problem started quickly. One time it worked, next it didn't. I have changed the fuse so that isn't the problem. Although the stove is about 12...
My Dimplex coal effect black Problem with the Dimplex Compact Electric Flame Stove Heater My Dimplex coal effect black stove won\'t work. The problem started quickly. One time it worked, next it didn\'t. I have changed the fuse so that isn\'t the problem.Although the stove is about 2yaer old, I have only used it about five times as it is in my drawing room that I sit in rather infrequently.I do hope you will be able to advise me the source of the problem.Thank you. salvador -
Oct 31, 2010 | Ovens
Hi, Last night none of the Dimplex storage heaters in my home came on. I checked the fuse box and nothing has been trippped. They were working fine the night before and I cant think of any reason why they...
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
Dec 15, 2009 | Dimplex DS5603 Heater
Dimplex DS5804 (similar to DS5603) turns on, but no fan to push heat.
A simple way to check the thermostat is to by-pass it. remove the wires from it, and connect them together. If the heat works after that, Its a no brain-er. The thermostat is just an adjustable temperature controlled switch.
Feb 26, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
