Question about PANDIGITAL Tablets & eReaders
My pandigital tablet is frozenat the startup screen - i cannot turn it off and it will not change the display on the screen. i used it to read last night without problem
  • Anonymous Mar 16, 2014
    my daughters tablet was working fine until last night when she tried to cut it on to play it it would go to the polaroid screen and just on it what could be wrong with it?
    New Friend:
    Problem Solver:
  • 7 Answers
Check the manual if you have it
Posted on Dec 03, 2012
3 Suggested Answers
joeguest2
  • 2080 Answers
SOURCE: user manual for pandigital planet
First of all, thank you very much Michelle for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://tabletsetc.com/upload/manuals/pandigital-planet-manual.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Posted on Dec 16, 2011
  • 4961 Answers
SOURCE: have a white screen on tablet can' turn off nor on pandigital
Very gently unplug the battery cable for two minutes.. I used a pair of tweezers and worked it out. Plugged it back in and it is fine. What a relief. I have read that if it goes to sleep while plugged in via usb, it freezes? Don't know. Just be careful when pulling the battery!
Posted on Jun 26, 2012
I have a pandigital 10 tablet and the screen is broke can it be fixed?
Possibly, if you are willing to tackle the job yourself.
The screens are made by a limited number of firms but you will need to get the exact model number which will be on a sticker on the back of the display module.
These are normally attached with a fragile, flat, ribbon cable plugged into the display's connector.
To access this you will need some patience and a few tools.
You will likely find the display for sale on line from multiple vendors.
Look at the video linked below to see if this is something you want to try:
pandigital tablet lcd screen repair Bing Videos
Your 10" tablet may be slightly different but the principle is the same and having it repaired by a profi will likely not be an efficient way to spend your cash.
Feb 03, 2015 | PANDIGITAL Tablets & eReaders
I have a Pandigital Supernova 8" tablet (I think it's model number R80B452). When I turn it on, the startup screen (white and blue with Pandigital in the upper right corner) just keeps flashing on and off...
there is a pin hole sized opening on the back of this tablet. This is the reset switch. turn the unit on then take a small paperclip or a pin and put it in the hole and push. you should feel the switch click. hold it for about 2 seconds then release. then turn it back on.
Nov 04, 2013 | PANDIGITAL Tablets & eReaders
How do i unfreeze my android tablet
My Pandigital screen is frozen, all I get is a green android with a triangle with an explanation mark inside it. How do I reset this?
Oct 28, 2012 | PANDIGITAL SuperNova
Have a white screen on tablet can' turn off nor on pandigital
Jun 25, 2012 | PANDIGITAL Tablets & eReaders
How do i reset the pandigital novel white 7
Hello.
To reset your tablet: (found online):
  • Press the "Power" button on the Pandigital Novel to turn it on.
  • Tap the "Settings" icon at the bottom of the Home screen display, then scroll down the Settings screen to the "Privacy Settings" option.
  • Tap the "Privacy Settings" option, then tap the "Factory Data Reset" option on the next screen. You will see the "Confirm" prompt appear. Tap "Yes" to begin the reset process on the device.
  • Hope this helps.
    Jan 07, 2012 | PANDIGITAL Tablets & eReaders
    I HAVE A PANDIGITALSTAR ANDROID TABLET WHEN I TURN IT ON IT STAYS ON THE WHITE SCREEN AND SAYS PANDIGITAL WITH THE BLUE DESIGN BUT I HAVE NO ICONS AND WHEN I PRESS THE BUTTONS AT THE BOTTOM NOTHING HAPPENS...
    had same problem. I figured it out. While pressing the home key on the bottom of the tablet, press the on/off button until a black screen appears with green words on the side, which says upgrading...please wait...wait. It should take you to the Pandigital screen with a small bar underneath it with green going across. It should work.
    Dec 15, 2011 | PANDIGITAL Digital Book 843967071153...
    It comes on by itself every 15 min
    Have you tried resetting the Pandigital. There is a small hole that you can put a paper clip in and it will reset the reader. It will take a few minutes to reboot after you press the reset. You should also go to the Pandigital site and update the reader. I have attached the link to there site.
    Thanks for using FixYa
    http://www.pandigital.net/Downloads
    Jun 19, 2011 | PANDIGITAL Digital Book 843967071153...
    I just purchase Pandigital multimedia novel 7"
    It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
    http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
    Hope this helps thanks for using FixYa
    May 13, 2011 | PANDIGITAL Digital Book 843967071153...
    Tablets & eReaders Logo
    126 people viewed this question
    Top PANDIGITAL Tablets & eReaders Experts
    Colin Stickland
    Colin Stickland
    castletech
    castletech
    Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
