Question about Lands Phones
Hi, the KX-T667 i'm using always has the red light on. (top right corner of phone). the dial tone is different too, what is wrong?
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
Posted on Nov 14, 2009
cnavarro
  • 2460 Answers
SOURCE: can not get kx-t7885 to get a dial tone
How are you trying to get an outside line? By dialing 9? If the host system happens to be a TA series, you have to tell it how many lines you have, or that you don't have lines that have hardware ports but no dial tone, since systems select outside lines from the top down.
From System programming, program 400 defines connected lines.
Carl
Posted on Nov 22, 2009
SOURCE: Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Posted on Feb 20, 2010
  • 20 Answers
SOURCE: our phone seems to be stuck in the intercom mode.
try pushing the intercom button again
Posted on Jun 14, 2010
ashehri22
  • 37 Answers
SOURCE: Cannot get Dial Tone on
Is it dial lock?
Posted on May 11, 2011
Panasonic kx-tg2511e two-tone dial tone
It's stutter dialtone and indicates you have voicemail. Once you clear your voicemail the stutter tone will go away. You may also have a visual indicator that you have voicemail like a light or icon on the display.
Oct 23, 2012 | Panasonic KX TG2215S Phone (KX-TG2215S)
Kx-td7896 no dial tone
hi re check might have wrong connections in the telephone connector ( box )
Sep 06, 2012 | Panasonic Lands Phones
Two questions: We have Panasonic KX-T7630 model How do I change/delete numbers to the personal speed dial numbers. Second, one of our phones has two buttons on the right lit up in Red like there are no...
If you mean the 10 number stored in 00-09, from the phone, pick up the handset (or press intercom) and dial *30 00-09 9 plus the number and # You'll hear a confirming tone. That stores the number. To dial, you press Autodial *00-09 and it dials the number.
What's under the buttons? Press PROG and the button and it will show what's there. Probably a digital station that isn't there. Press 2 and STORE and you'll clear the button.
Carl
Sep 28, 2011 | Panasonic KX-T7630 Corded Phone
How do I program different ring tones for the KX T7220. THere are 6 to choose from I believe.
1 Press program key
2 Dial 99
3 Press line key or intercom key twice
4 Dial 1-8 for tone type
5 Phone will ring with new tone
6 Press store button(autodial)
7 Press program key to end
Dec 07, 2010 | Panasonic KX T7220 Corded Phone
Dial tone on speaker-phone but no dial tone on line 1
Either button mapping or no dial tone at the system cabinet. If your desplay sas CO1 and you have no dial tone, go to the sytsem cabinet ans swap the modular plugs for CO1 and CO2. If the No Dial Tone moves, "mus be sumpin wrong wit yo lines".
Carl
Aug 13, 2010 | Panasonic KX-T7730 Corded Phone
Jan 23, 2010 | Panasonic Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Problems with handsets
Are they cordless phones?If they are they get there dial tone from the base.If there is a blinking red light on the hand sets they lost communication with the base.Check your user manual to see if you need to program them to the base.
tk46
Jun 09, 2008 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Lands Phones Logo
64 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
