Question about Locks & Locksmithing
Would like to change code for trilogy d 2700 keyless door lock
  • 3 Answers
SOURCE: code change for trilogy lock D2700
First find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version. Old version remove battery and press any button. New version remove battery, press any number for 10 seconds,release, reconnect battery, press and hold the A button within 3 seconds, 6 beeps, release A button. the lock is at default and ready to program. To program new version 12345 A1A new combo A new combo this will set a new master code, if you are only using 1 code to open the lock this should suffice.
Posted on Jun 12, 2009
  • 3 Answers
SOURCE: Trilogy dl 2700 serries digital lock program managers code
First you need to know if you have a standard 2700 or the new enhanced version, it makes a big difference. Press any 2 buttons then star, if you get no response it is a standard version, if it beeps several times it is the new version. If it is the standard version, disconnect the battery and press any button. Now you are at factory default. Reprogram the master code, remember the master code and the operating code must b e the same length. 12345 A 1 A new master code A new master code. The master code is the only code that needs to be entered twice during it's programming. To set a manager code press; master code A2A new manager code, to set a new user code; enter master code or manager code A11A new user code. The programming must be done during the lock's unlock window so write down the procedure you intend to use to make things go quicker, if you need more time you can change the unlock window, it is probably set at the factoy 5 seconds. Press master code A45A4, this will give you a 20 second window to program the lock, when you are finished change the lock back to 5 seconds, press; master code A45A1, keep the open window short to conserve batteries.
Posted on Jun 24, 2009
SOURCE: lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
Posted on Jun 26, 2009
  • 963 Answers
SOURCE: I have a Trilogy DL
This is the website for Alarm Lock, the manufacturer:
http://www.alarmlock.com
Then please contact them for technical assistance.
Posted on Nov 08, 2011
  • 963 Answers
SOURCE: i need an instruction to change combo code for Trilogy Alarm Lock T2 TRILOGY
You will find installation and instruction manuals on this web page:
http://www.alarmlock.com/tech_library_instruction_manuals.asp
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 15, 2011
Were do i get battrrey pack for dl 2700
According the installations instructions for the DL 27, the DL2700 uses five AA-size 1.5 volt alkaline batteries.See Page 11 of the installation instructions:
http://napcosecurity.com/download/DL2700_OI209A.37_PROG.pdf
Apr 20, 2011 | Trilogy Alarm Lock T2 TRILOGY® Digital...
My Nokia 2700 Classic is locked I want to Operate it in Egypt but as I said it is locked .
Please re-categorize your question from door locks to cellphones for a solution.
Mar 30, 2011 | Trilogy Alarm Lock T2 TRILOGY® Digital...
I have a Trilogy DL 2700 lock on my secure facility, we changed the code about 2 weeks ago, the green light is active however the door handle part is not locking today and people are able to enter with...
Oct 21, 2010 | Trilogy Alarm Lock T2 TRILOGY® Digital...
DL 2700 Alarm lock malfunction with constant alarm
I have had this happen on a 3500 and I had to replace the keypad assy. But, you may want to try to restore factory settings just to see if it resets. Disconnect the battery pack and hold down any number key for 10 seconds (this bleeds off any charge that may be in the capacitors). Reconnect the battery and within 3 seconds, press and hold the "A" key. After hearing 6 beeps, release the "A" key and wait for 5 seconds for the lock to re-lock (listen for 1 beep and red LED).
If successful, this will reset factory settings, which means the master code is now 1 2 3 4 5. If you need a programming manual, go to www.alarmlock.com At the top of the home page click on "support". Scroll to the bottom of the support page and click on Technical Library. Scroll down that page and find "trilogy DL programming manuals" and under that click on "download DL2700 enhanced instructions". I hope this is some help!
Feb 22, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Feb 18, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Locks & Locksmithing Logo
42 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
