Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
How to replace the waste ink pad in a HP Officejet 6500
Cleanlng the waste ink well
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
SOURCE: HP Officejet 6500 No scan Options
I am trying to scan, but when I press the scan button it states "No scan options. Refer to device doc to troubleshoot". However, I can't find my device doc. I am assuming there is an easy fix?
Posted on Dec 19, 2009
  • 5 Answers
SOURCE: Cannot coonect SCANNER (HP Officejet 6500 wireless) to my Windows
I have seen alot of problem/posts concerning HP AIO's and software issues. Typically some of the functions won't work or not recognized by solution center. Try a complete uninstall of all associated printer software, run registry cleaner if you have it, restart, then try completely uninstalling your Antivirus/firewall software. I have seen that just disabling Antivirus/firewall still causes faulty installations. Now, reinstall your printer software/drivers and connect cables only when told to do so. Some reason the AV/FW software blocks some of the AIO's apps from completely installing.
Hope this works...Good Luck!
Posted on Jun 12, 2010
djgillstudio
  • 107 Answers
SOURCE: HP OfficeJet 6500 Wireless - repeated ink system
hello, i'm sorry about the problem you are having, the problem will probably be 2 fold, one is printhead, and last maybe inks, hp recommends taking inks and printhead and cleaning contacts, and re-installing, and try again, what i have done was go thru chat on hp's web site and explaine that i have done all they're instruction, and nothing worked, they eventually sent me new printhead and inks. i would try going that route, the chat was better than trying to call they're phone support.
Posted on Oct 06, 2010
azeroth009
  • 65 Answers
SOURCE: HOW TO RESET 920 INK
FYI, you cannot reset the ink it self. If your using an HP refilled ink cartridge the warranty of your printer will be void. you need to contact HP right away to purchase new ink cartridges.
If the cartridge has been refilled or remanufactured, 'Low on Ink' or 'Ink Alert' messages may be inaccurate or display incorrectly.
Posted on Jan 31, 2011
Black ink will not print on officejet 6500
Replace print head assembly.. P/No: CD868-300018_20_2012_7_36_36_pm.jpg8_20_2012_7_37_03_pm.jpg
Aug 20, 2012 | HP Officejet 6500 Wireless All-in-One...
I have a hp 6500 officejet wireless printer that i jut put in new ink cartridge and all it does is print blank pages?
This happens as the ink needs some time to saturate the system. Usually one needs to print quite a few pages for the ink to flow through and get to the ink head. A better quicker way is to clean the ink heads with the aid of the software that came with your printer.
Navigate to your windows control panel and double click printers and faxes. Then right click on your HP Officejet 6500 printer and select properties. Then click the Print test page button. Check the manual for cleaning the ink head.
Take care!
damnor01
Aug 30, 2011 | HP Officejet 6500 Wireless All-in-One...
I just replaced by black ink on HP Officejet 6500. It will not print black thought it maybe the cartridge I replaced it again. Still want print. I tried three new cartridges. The color works...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Jul 24, 2011 | HP Officejet 6500 Wireless All-in-One...
HOW TO RESET 920 INK CARTRIDGE ON HP OFFICEJET 6500 AFTER HAVING IT REFILL
Jan 31, 2011 | HP Officejet 6500 Wireless All-in-One...
Have HP Officejet 6500; how do I load the ink refill?
Ink refilling is done by many refillers.so better you just go to refill there.because ink price are verry high,also the inks are wasted within 6 months.if you need to know about the ink refilling just visit the web address:http://www.youtube.com/watch?v=ayschOFzwP4 and
http://www.wikihow.com/Refill-and-Reuse-a-Printer-Cartridge
All the best...
Dec 02, 2010 | HP Office Equipment & Supplies
Reseting ink 920 cartriges
Download the manual for HP 6500,
HP OfficeJet 6500 Wireless Manual.
It is clearly mentioned in it.
-Rate if it helped you.
Apr 10, 2010 | HP Officejet 6500 Wireless All-in-One...
Recently bought an HP Officejet 6500. How do I
even though my laptop has been to the hp laserJet 1010 printer, the printer doesn't print !
Oct 31, 2009 | HP Officejet 6500 Wireless All-in-One...
60 days old hp 6500 ink jet failure
See for any local Computer Technician or bring your printer to computer to make sure that your new ink cartridge works.
Usually this problem occur when a lot of waste or unable to clean physically the printer.
I'm sure 100% works with consultation to your printer.
A lot of problems are not even identify directly with only one new ink attack. Failure to print, hardware detection, mechanical problem & etc. are only problems may have.
Hope this tip might you a lot.
Sep 23, 2009 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
200 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
