Question about Acer Aspire 5315 Notebook
Blank screen when i turn on the laptop it goes to the acer load up page then says press f2 to enter setup or f12 to change boot order then goes to a black screen. i thought about doing a system restore on it but cant even get to the log in page.
  • pcplunkett Jan 11, 2009
    ive tried all that, its my mum in laws so i havent a clue what shes done to it lol.
    when i get press the f12 i click on it all to reset as default then save but still does the same.
    any ideas on rebooting it without going into the settings
  • Acer Master
  • 5,568 Answers
Have you tried starting in the 'Safe Mode?'
If not, either F5 or F8 (right after anything  appears on the screen) will bring up a short menu to allow you to choose the boot mode; choose the Safe Mode. This loads only the most basic windows files and will let you do some fundamental checking of the hard drive and Win installation.
If you can get that far, Click on 'Start,' then 'Run' and enter 'rstrui' and OK. This should start the Restore routine.
If it does, choose 'Restore to an earlier date.' Hopefully you have had Restore turned on and then you will have a calendar with light and bold dates. Choose a date a few days in the past and let it run.
This may or may not put you back in operation.
Posted on Jan 11, 2009
  • Steve Allison
    Steve Allison Jan 11, 2009
    I'm afraid I can't help you other than the path I described previously; good luck.
Got an Acer 4050 from ebay and it goes straight to enter boot password
can you click on f12 before it goes to boot password?
The F12 Boot Menu allows you to choose which device that you would like to boot the computer's Operating System from by pressing the F12 key during the computer's Power On Self Test, or POST process. Some notebook and netbook models have the F12 Boot Menu disabled by default.
If this sounds like your problem then try this:
If this sounds like
To enable the F12 Boot Menu:
  1. Restart the computer.
  2. Press the F2 key to enter computer's BIOS Setup during Power-On Self-Test, or POST, process while the Acer logo is being displayed.
  3. Press the Right Arrow key to select Main
  4. Select F12 Boot Menu
  5. Press the Enter key
  6. Select Enabled
  7. Press the Enter key
  8. Press the F10 key and then press the Enter key to save the changes and restart the computer.
Note: Not all Acer notebooks or netbooks have the F12 Boot Menu feature. Computers that do not have the F12 Boot Menu feature will not be able to enable the feature within the BIOS. I hope this works for you if not, then the problem is obviously not the boot menu. Go to Acer support for more help
Aug 30, 2014 | Computers & Internet
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 05, 2013 | Dell Latitude D800 Notebook
Change the f12 boot menu on an acer t180
Press F2 to enter BIOS setup at startup. You can set which devices appear in the list from the boot menu.
http://johnbokma.com/mexit/2007/12/22/acer-aspire-phoenix-bios-boot-screen.jpg
Jan 20, 2013 | Acer Aspire™ T180 PC Desktop
My laptop is not loading anything only it show toshiba logo then it goes blank screen i cant acces boot menu by pressing f12 i cant access bios setup menu by f2 when i press these it only show entering...
I would contact www.toshiba.com amd speak to the technical department, they are very helpfull. It may be a RAM fault or a hard drive fault but as you have data on the drive, I don't want it to go pear shaped and for you to lose any data.
Hope that helps.
Mar 09, 2011 | Toshiba Portege M800 Notebook
My acer aspire9410 disply is blank,i entered many time bios setup key F2 but it not showing bios setup page, pls help me to get in to bios page. before i tried lot one it was showing but it showing like...
-changeing bios-first restart computer then press[ f2] then get on key board use arrow key on key board go down you will see your boot log is on f2,change that on a f12, now push f10 to exsept settings now when asked restart computer then f12 then run windows under D:drive.
Feb 26, 2011 | Acer Aspire 9410 Notebook
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
My dell inspiron 1501 is stuck in bios about 75%
operating system isnt loading....try booting with a windows boot cd
Nov 21, 2009 | Dell Inspiron 1501 Notebook
My acer aspire one netbook tries to boot ,but then goes to a screen giving the choice of pressing f2 to go to setup,or to press f12 to change boot order.it wont even boot in safe mode or last known good...
i was able to go on the acer website on another pc and found that if when you turn on your acer and hold down ALT key while hitting F10 that will bring you to a system recovery screen. you can restore factory settings from there. It will wipe out all of your documents and pix but it does fix the problem.
Apr 19, 2009 | Acer Aspire One PC Notebook
Can't boot up my HP XE4100 laptop
press hard disk and boot the windows
Apr 01, 2009 | Computers & Internet
Brand new notebook .. windows then, screen freeze..acer picture
This may require a "repair" of windows.
Get a Windows XP Operating system disk with the correct service pack that the notebook has installed (usually XP SP2).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The XP CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5315 Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
