Question about GE JVM1850 1000 Watts Microwave Oven
Giving -F3- display and beeping 3 times, does not respond
I wiped the sensor pad with a dry paper towel to clean it. I may have pushed several keys, but now it shows an -F3- on the display, beeps 3 times loudly and will not respond to any command. If I unplug and plug it back in, it displays 'Push Clock' but will not respond to anything and after 30 sec. goes back to -F3- and the beeping. Any information is appreciated.
Thank you.
  • Anonymous Jan 14, 2009
    DISPLAYS F3 AND PAD WILL NOT WORK.
  • GE Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, you have a shorted / failed membrane keypad.
Until it is repaired, please leave it unplugged or leave the door open.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 12, 2009
Out of no where I get and F3 error messaGE AND A BEEP BEEP BEEP the model # is JES1036WF001
Hi
F3 error in your GE microwave means that the keypad/touchpad is bad and should be replaced. However, before replacing it you can follow these step by step instructions to clean the touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover moisture
8) After this put the keypad back if its not solved then replace it.
Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE Microwave Ovens
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't turn on code say's "F3"
The F3 error code for a GE microwave means the control is sensing a stuck or shorted key. Try pushing every button multiple times and do it firmly.
Hold a blowdryer in the corner of the keypad then slowly move it down as you peel it back (but not off). Take a sponge with the tiniest bit of dish soap and run it over both the sticky part (back of the circuits) and the place it is stuck to. Blowdry this til touchably dry and then reapply the kaypad face. Wait about 10 minutes until you plug in again for it to cool off.
If that doens't work, UNPLUG the unit and try to gain access to the electronic control board. If you can there may be a ribbon cable you can unplug from the board and try wiping the end of the cable hard between your thumb and index finger then wipe with a paper towel and reinsert the ribbon cable. May work but more than likely you will need to replace the touchpad.
Jun 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Benjamin
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error on Display
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
If it will not successfully dry out, it will need to be repaired.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
Sep 07, 2008 | GE JVM1870 Microwave Oven
The microwave suddenly beeped several times, the scroll directed to push clock button, but no button would respond and then F3 appeared on screen but no explanation. We unplugged microwave a couple of...
The code f3 is a short in the key pad for more than 60 seconds
go to GE .com and enter your model # and you can get a price to do it your self
Good luck
TEETERMAN
Aug 17, 2008 | GE Microwave Ovens
Ge spacemaker xl1800 microwave
F3 on a GE microwave indicates a defective keypad.
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
If none or only some of the pads are working, there may be some foreign substance on the circuit board, the keypad connection, or inside the layers of the keypad, the latter of which cannot be repaired.
Trouble is sometimes due to spray cleaner being sprayed directly onto the keypad. Cleaner should be sprayed on the cloth first, then use the cloth to wipe the keypad clean.
Never use an ammonia-based cleaner on plastic as the ammonia can attack and crack it.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out, but often that does not work.
Another thing is to unlpug the power at the mains for several seconds. Plug it back in and see if it works. A reset may do it.
At power-up, the display should flash or show a text message. If not, a key may be stuck due to a foreign substance or a defective keypad.
If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board.
To check that, see our critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa: http://tinyurl.com/yzjozk
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser or alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 02, 2008 | GE XL1800 1100 Watts Microwave Oven
MY MICROWAVE WILL NOT DO ANYTHING
I couldn't find those exact trouble codes, but a common problem is when the controller gets damp, either from steam rising from the cooktop or someone spraying cleaner directly on the keypad. Cleaners should always be sprayed on a soft cloth, then wipe the keypad with the cloth. Also, GE / Samsung codes of F1, F2 and F3 may be the same since Samsung makes GE microwaves. Those would mean trouble with the temperature sensor, keypad, or control panel. Assuming your control panel is clean and dry, it may be time to call for service.
Apr 04, 2007 | Samsung MW1080STA Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
148 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
