Question about FrancisFrancis! Coffee Makers & Espresso Machines
Can I adapt a Francis francis x1 to take ese pods?
If I buy a ground coffee only machine is there an attachment I can buy to convert it to use pods?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
My X1 came with an ESE pod holder and a ground coffee holder so they are definitely available.
Posted on Jan 23, 2015
4 Suggested Answers
SOURCE: I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Posted on May 21, 2009
EsWorld
  • 1618 Answers
SOURCE: Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
Posted on May 31, 2009
  • 5 Answers
SOURCE: I have a Francis Francis X3 machine and would like
If you have an X3 Trio you are out of luck.
If you have the older model, you can buy 'ground coffee conversion kits' or you can use a ground coffee portafilter from an Ascaso Dream/Arc etc.
See: http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html
Posted on Nov 06, 2009
Do I have to use k-pods exclusively
No as long as they say they are keurig compatible they will work. You can also purchase empty reusable pods that you can fill with your favorite ground coffee of loose leaf tea.
Feb 21, 2015 | Keurig Coffee Makers & Espresso Machines
Verismo 801
Sounds like a problem with the pods. Check they are manufacture recommended. When on espresso the pressure will be higher so a
"weak" pod could cause this. Unless the machine is producing too high a pressure. Check also there are no projections that could rip the pod when you close the holder.
Jan 28, 2014 | Coffee Makers & Espresso Machines
What are coffee pods? Someone told me to use them in my coffee machine?
Some coffee machines have the option to either use ground coffee and filters or coffee pods. These are small, sealed containers that have the ground coffee inside. You insert the pods into the machine and click them into place. The machine pierces a hole and the water drips through. It's a much tidier way to make coffee especially if you don't drink a lot of it, so you don't want a whole jug full, rather just one cup at a time.
Feb 25, 2013 | Home
I have an Ascaso Dream - pod only version. I would like to know if the portafilter is replaceable. I want to exchange it with the model that does both ground and pod coffee. Thx, Rasmus from Denmark
Hi Rasmus,
If your model is pod only - fixed version - then it is not possible to replace the group.
If you have a pod portafilter then it is possible.
You will need: . a new portafilter and ground converter kit Ground coffee converter Kit ASCASO porta filter complete
Sep 04, 2010 | Ascaso Dream Espresso Machine
I have a Francis Francis X3 machine and would like the attachment to use ground coffee as at the moment I can only use pods.
Oct 29, 2009 | FrancisFrancis! X3 Espresso Machine
Need to convert gaggia baby from capsule use to regular coffee
Yes, as far as I know most machine that use pods just have a different portafilter, because of the way the pods are setup.
Jun 23, 2009 | Gaggia Baby Espresso Machine
Briel Chamonix es35 New..
Pods are expensive. I buy espresso grind from my favorite local espresso shack and I take regular drip coffee filters and cut small discs from them to put in the bottom of the cup that holds the grounds (moisten first). It works great and keeps the finer grounds from clogging it up.
Feb 21, 2009 | Briel Chamonix ES-35 Espresso Machine
Senseo stuck after using coffee pods that have "milk" built in....5 days later
I had the same problem. I waited for a while as the instruction says but didn't open. But, I got it open!!! by turning and slightly pulling a small plug behind the water tank on the backside. (remove the water tank then you'll see the little plug. see attached photos) I think it will let air in and vacuum seal get released. After it opened, I gently turned the plug back and push it in as it was. Now, it is running perfectly again. I just had a great coffee. :-)
58c3f6de-9c9e-437e-b419-0533bdf0a452.jpg562b78da-5cdf-43fe-afb9-546e2ba78530.jpgb5d600f7-721a-4b74-a954-ef849424bf28.jpg
May 14, 2008 | Philips Senseo HD-7810 Coffee Maker
Open Questions:
Coffee Makers & Espresso Machines Logo
137 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
billconfused
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
