Should the glass on a black beauty oxysafe serial no 466-94 have a gap under it
I have been told by a gas fitter that the glass panel on my fire should not have a gap underneath it.is this correct please.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: gas fire is making glass and ceramics black. It
If you are getting black soot them the air/fuel mixture is not correct. Yes, usually it is a sign that you are getting too much gas...
However the problem could easily be that the air shutters are closed partly or dirt has plugged things off enough to mess with the air fuel mixture.
Without knowing exactly what you are talking about it is very difficult to give exact troubleshooting procedures...
I assume you are talking about a gas fireplace of some type...
They are historically very susceptible to dust and dirt which clogs the burner and air ports causing them to smoke..
A very good cleaning yearly is very important for proper operation...
Blow everything out with compressed air as you completely disassemble the unit and put it all back together again...
Generically I would find out the BTU output of the burner and then check the gas pressure or clock the meter to see what you are getting into the burner.
Then after making sure the proper fuel is going in then I would work on the air/fuel mixture and getting a good flame.
To do this may take specialized equipment and even after getting a good flame the combustion should be checked with a combustion analyzer to be sure the you are not producing harmful amounts of CO (Carbon Monoxide).
The best person to do all of this is a professional that has experience with the type of equipment that you have and knows how to setup the equipment to work safely.
After people die it is too late and it does happen...
Heatman101
Posted on Nov 04, 2010
Testimonial: "great many thanks for the help, i will follow through and let you know when all sorted. ps this is a new fire. regards Vicki"
Hello...i have a black gibson les paul custom. Serial number 00117886. what year is it and would this be considered a black beauty? any idea of value too?
The term 'Black Beauty' has been well overused by now. It was originally the 1957 black Les Paul Custom model, but by now is any black Les Paul Custom. In addition Gibson themselves are cashing in by doing reissues, finished to look older.
So if it is a black Les Paul Custom, then yes, it is a Black Beauty, according to someone somewhere. On top of that, Gibson has reused serial numbers, in different years for different models.
If the serial number is stamped on the headstock with 'Made In USA' the guitar was made at the Kalamazoo or Nashville Plant, in 1976.
Those guitars are worth US$3000-4000 depending on condition.
Otherwise it was made at the Nashville Plant, TN, on January 11th, 2007.
Those newer reissue guitars sell for similar prices.
Feb 24, 2017 | Gibson Music
How can i fix my gas fire place
You can't unless you a government registered gas fitter. Incorrectly installed or serviced appliances gas people and blow up homes. Get someone in to service it.
Nov 15, 2015 | Napoleon 36" Zero Clearance Top/Rear Vent...
Flame leaking under lower ring. Common?
no it is a problem with the hob
consider this
as it is a rental property it is the responsibility of the land lord to get a gas fitter in to fix / replace the problem
If you do not ask him to fix it , if there is a problem and the thing explodes, catches fire or gases some one to death, there is every possibility that he will try to blame you for not reporting it
if he refuses to fix it or tries to fix it himself then I would advise that you seek alternative rental accommodation as the problem is for an accredited gas fitter and not a landlord.
Sep 23, 2015 | Smeg 23 in. SE64 Gas Cooktop
Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
Jul 15, 2014 | Rinnai Heating & Cooling
Connect gas cooker
You may have to seek a gas fitter who knows how to make the connection.
Dec 10, 2013 | Electrolux Cooktops
Hiya. I have an old baxi boiler wm 38/RS . The pilot light is on but the boiler will not fire up . Can u help me
Rubbish!
Cleaning the jet is a job ONLY for a gas fitter as it involves disturbing both the case seals and the gas pipework. DON'T RISK YOUR SAFETY, besides which if the pilot wasn't powerful enough it would continually go out.
Check (if you're competant to do so) that there's 240vac across the gas valve solenoid connections. If so then the gas valve will need replacing by a GAS SAFE REGISTERED fitter.
FYV
Jan 18, 2013 | Combi Centre DX - Mango
Hi I have an old school (30yr approx) vulcan gas heater works brilliantly but the glass has gotten very sooty (blackened) can I dismantle to clean & how??
if the glass is sooty then cleaning it will not solve the problem , its not burning right causing the soot , needs to be serviced by a gas fitter.
Jun 30, 2011 | Vulcan AUW230A Heater
Where would you find the makers name on a gas fire which I have bought second hand. I need to establish how the 'coals' are arranged? My gas fitter can finish the installation. Thanks, Mark
look underneaththe fire it could be on a swing out lever or on a wire or onn ther bottom panel , your gas fitter should know where to look
Aug 09, 2010 | Heating & Cooling
We have a Valor Model 466 Black Beauty OXYSAFE Fire, when you turn the sparker on the fire lights and you hold it down for a short time but as soon as you release the ignition the flame cuts out. We have...
It sounds as though you have a bad thermocouple. Replacing the thermocouple which senses the heat from the flame should correct your problem. The thermocouple is a safety device which when working properly sends an electrical signal to the main gas valve that your pilot lite is on and holds the valve in the operational mode.
Nov 04, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
