Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca 52in Projector
My big screen tv keep blinking off 3 times but it won't come on afterwards.I hear clicks when the light come on and then cut off I tried unplugging the cord for an hour nothing still the same. I hope it's a minor problem. Can you please help me. Thank you
  • 203 Answers
Most likely the issue in on the large signal board. The TV is going in to shutdown. Repair might run $200.00 or so.
Posted on Jun 08, 2007
Light bulb not working after colorwheel replaced
Same thing happened to me (By jschmidbauer on Jan 14, 2010). How did you fix it????
Jan 14, 2010 | Samsung - Projection TV replacement lamp...
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
Picture problems
try this push left or right arrow key on remote to change the fomat
Dec 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Oct 29, 2008 | RCA D52W19 52" Rear Projection Television
Tv repair
Does the power indicator blink? If so let me know how many blinks it blinks. Respond to this post so I have a way of keeping your symptoms and model number available for furture responses.
Jun 23, 2008 | RCA D61W20 61" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Rca 52in p52921yx2 need help
if this problem happens after such aive mins and it is consistently giving that same problem to every time the set is turned on then it is a cold solder in your circuit of the video.if it gives that problem on start up ten the video amp and related circuit should be checked.have a tech check your tv.good luck.
Apr 15, 2007 | RCA P52921 52" Rear Projection Television
My tv will not turn on
I took my TV apart and solved the problem on my own. For those of you that have basic electrical skills and can solder it is an easy fix that only takes about one hour. I removed the rear cover and pulled the left side board which houses the flyback transformer, easily identifiable by the big orande wire coming off of the top. If one looks carfully the soulder connection will probably be broken or loose which can be caused by movement or heat. I resoldered all of the connections for the transformer about 12 and the grounding wire to the left, a single black wire that plugs into the board. Once this was done I put ti all back together again and no problems since!
Oct 29, 2006 | RCA HD52W58 52" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
191 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
