Question about Ovens
My oven Ilve clock wont stop beeping and it buzzes every so often and switches it self on and off
Display flickers on and off when it buzzes then switches itself off for a couple of hours then when it turns itself back on it starts to beef on and off
SOURCE: Oven will work for about half an hour and then turns itself off.
it sounds like the thermal cut out is broken can be replaced quiet easy need to disconnect oven from mains remove outer cover and has four wires two blue two white all with spade connectors can be bought from e spares on the web
Posted on Dec 08, 2007
SOURCE: Error Code F8
Try http://www.applianceaid.com/fault_codes.html
Posted on Jan 06, 2008
SOURCE: I have a Frigidaire 30" self cleaning oven that is a stand alone...the oven stopped working this past weekend
have your electronic timer sent for repairs, go on internet at ApplianceTomers.com
Posted on Nov 11, 2008
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
SOURCE: New World G70m Gas Double Oven switches it self off
Was sorted out with insurance from New World and it turned out to be a circuit board and all knobs replaced. You can get circuit board on ebay for about £38.00 plus postage if you are capable of fixing it yourself.
Posted on Jan 31, 2009
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
I have a zanussi zcg7690xn double oven. the digital clock is not working and i cant use the bottom oven. there seems to be power up to the clock as i can hear it buzzing but there is nothing on the display...
I HAVE A ZANUSSI ZCG7690XN DOUBLE OVEN. THE CLOCK IS NOT WORKING AND I CANT USE THE BOTTOM OVEN EVEN THOUGH THE IGITION IS SOUNDING IT WONT LIGHT. I CAN STILL LIGHT THE TOP OVEN AND THE RINGS FINE. PLEASE CAN YOU HELP. AWAIT IN HOPE. REGARDS MO
Jan 30, 2010 | Ovens
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
F1 error
I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
Nov 13, 2008 | Maytag Ovens
Oven
Aug 07, 2008 | Ovens
F0 display error
ok fo is a communications error and can be in three places the manuel says replace the eoc but ive found that's not always accurate if this is a free standing or slide in range you can pull it out and remove the back top and bottom when the oven goes in self clean the door switch has two functions when the door is open it tell the clock that the door is open and the door latch motor and it turns on the oven light when the door is closed it turns off the oven off and tells the clock and latch motor the door is closed it does this by two micro switches on the latch motor one for closed one for open by means of a plastic cam on the latch motor now if you have self cleaned the range lately then the door locked micro switch may have stuck when the cam rotated back to the unlocked position and with both switches closed the eoc wont let the oven work because it thinks that its in self clean also ive seen mice build nests on the platform that the motor is mounted on and pile insulation on the closed switch and close it that way so you got the door switch the latch motor switches or the mylar ribbon that goes into the eoc its self could be dirty now on the clock or eoc there is a little lock tab at the bottom of the ribbon that you pull up and release the ribbon and gently clean the ribbon and replace it now when testing the switches with a ohm meter you must remove one wires from the switches to prevent getting a false Reading if all this fails then replace the clock now you can call a repairman but most like they will replace the clock without checking the other stuff now is this a free standing range also some where on the range will be a tech sheet with wiring diagram ans stuff it will help you is this a freestanding range or a slide in as componets are located in different places if you need more help reply to me
May 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
