Question about Linksys Wireless-G WRT54G Router
WRT54G intermittently working
I have 2 PCs wireless hooked and cannot get them to consistently work. My husband says I need a new router--not sure if that is the case or what. I am computer illiterate !!
  • jumack Jan 11, 2009
    Will go and buy one--thanks !
    President:
  • 623 Answers
Well...buying a new router might not fix the problem if you can't find the cause for it.
Blueextc is right that the signal could be weak or interrupted. (Just on a side note: he is wrong about the frequencies. 802.11b and 802.11g use the 2.4 GHz ISM band, 802.11a uses the 5 GHz U-NII band, and 802.11n transmit at a frequency of 2.4GHz or 5 GHz)
Therefore, sometimes a wireless telephone, if placed too closed to the router, can cause interferece, because it is also working in the 2.4 GHz spectrum. Microwave, cabling in the wall - all reasons for bad reception.
So just buying a new router might not solve the problem.
Upgrading the firmware or - even better - changing to something like tomato, can solve a lot of issues. If you need assistance with the procedures, come back here and I am happy to help.
Posted on Jan 11, 2009
  • 15,935 Answers
You may have a signal-path problem or interference - not necessarily from your house.
The "g" speed routers work on the 900MHz frequency bandwidth.
Newer "n" routers are backward compatible, and use the much faster and reliable 2.4GHz. The wavelengths are significantly closer together, and outside interference is almost none.
In part he is right - getting a new router "N" will eliminate your connectivity problems.
    Sniper:
  • 87 Answers
It could also be a bad wall plug power supply, depending on your budget, find a replacement power supply or just buy a new router with potentially the same problem.
Trying to hook-up a wirless router (Linksys WRT54G) to a SpeedStream 5100 for PS3 gaming on-line.
Before we configure router with PS3, we need first to make sure router is already configure to work with DSL modem. In Setting-Up a Linksys Router Using DSL Internet Service just click this link for reference.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=7a7ce39e35c34b5a9f641429eddc075f_4521.xml&pid=80&respid=0&snid=1&dispid=0&cpage=search
And for PS3 configuration to connect wirelessly to a wireless router, just access the link below
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=6dd5053ce9dd47ef9a78dd0623966bec_20556.xml&pid=80&respid=0&snid=3&dispid=0&cpage=search
Cheers,
Aimee
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
My problem is that on my daughters computer it says connected with limited access. yet on the main computer where the modum is placed the internet works fine. my daughter has claimed she did not do...
Hello
Try to reboot the router.
1 shut down all pcs connected to router.
2 Unplug all cables from router,mark them if you think you will forget.
3 Unplug power from router also.
4 In the back of the router there is a small reset button hold this in for 1 min with a pen tip or a paperclip.
5 Replug everything back into router,power up router.
6 restart your pcs.
Nov 29, 2010 | Linksys Wireless-G WRT54G Router
My WRT54G router has been functioning flawlessly for three years... until today. All of a sudden, neither my laptop nor my Blackberry don't see the wireless network... although the 2 PCs that are...
If you have a modem unplug it then unplug your router, wait for 2-5 min then plug in your modem then router. It always seemed to work for me. If it dont work call Linksys.
Oct 15, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54G: Has worked great for years. It recently reset itself (lost encryption). At same time: wireless works for about 60 secs then disconnect; then next day, wireless works perfect. Then:...
if it is working but intermittently most probably you may need to update your routers firmware online... go into your routers GUI " Graphical User Interface settigns page there should be an option for you to update the routers firmware... also try calling the routers manufacturer give them what model your router is for them to check and give you info if there are updates available for the specific router you have. if it connects it is ok it it gives an error something is incorrect in the settings.
Jun 28, 2010 | Linksys Wireless-G WRT54G Router
WRT54G keeps disconnecting itself, requires disconnecting/reconnecting power and running setup disk again to reconnect. System info: 12 mb/s cable broadband ISP, Motorola SB5105 cable modem, WRT54G...
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Mar 04, 2010 | Linksys Wireless-G WRT54G Router
The conectivity is not consistent. I frequently
I would advise investing in a new one, it does sound like its componants are begining to fail.
Jan 20, 2010 | Linksys Wireless-G WRT54G Router
Im hooking everything up right as im going through the 4 step intallation disk and it says Your new router does not appear to be connected properly.
make sure the cable going from your laptop/computer is connected - you NEED to be connected! or if you are going wireless and you know that your laptop wireless adapter is working and you can see the default wireless network - which is "linksys" (without the quotes) you should be able to connect to it and configure it without the CD..
Dec 30, 2009 | Linksys Wireless-G WRT54G Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Laptop could not detect linksys on second day
Jatman,
Couple of things you can try here:
1) Connect your laptop (or another computer if possible) to the router using a network cable. You should then be able to see your configuration info. Make sure that the computer you are using to connect (wired) to the router is set up to use DHCP. Once in there, depending on what you find, you might be able to fix it yourself.
2) Factory reset the router and go through the setup options as if it were brand new.
Hope this helps.
May 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
110 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
